studio-web
Studio Web for Automation Suite User Guide
Last updated Dec 19, 2025
The Validation Control variable
Each Validation Control automatically creates a variable inside the app. This variable holds the document data and you can use it in other parts of your app or automation.
The variable name follows the syntax Var<ValidationControlName>_<PageName>, for example VarValidationControl_MainPage.
The Validation Control variable allows both reading from and writing to the Validation Control.
Apps automatically manages this variable:
  • Creates the variable when you add the Validation Control onto the canvas.
  • Renames the variable when you rename the control.
  • Deletes the variable when you remove the control.
  • Prevents you from manually deleting or modifying this variable, since it is protected.
  • Provides usage across different app pages, as the variable is app-scoped.
Variable properties
The Validation Control variable includes several properties you can reference or bind:
  • Taxonomy—Holds document schema, field definitions, and labels.
  • ExtractionResult—Contains extracted field values, raw and validated.
  • SelectedDocumentType—The active document type shown in the control.
  • SelectedField—The field currently selected by the user.
  • BusinessRules—Status of field-level validation rules.
  • IsValid—Boolean flag to override control validity.
  • DataSource—Holds the original ContentValidationData object.
Reading data
To read the current state of the Validation Control content, use the following expressions:
  • Getting the extracted results
    VarValidationControl1_MainPage.ExtractionResult
  • Getting the selected document type
    VarValidationControl1_MainPage.SelectedDocumentType
  • Getting the selected field and its values
    VarValidationControl1_MainPage.SelectedField.FieldValue.Value
    VarValidationControl1_MainPage.SelectedField.FieldValue.Confidence
  • Getting taxonomy fields (useful for dropdowns)
    VarValidationControl1_MainPage.Taxonomy.GetFields(VarValidationControl1_MainPage.SelectedDocumentType).ToListSource
  • Reading a table field value
    VarValidationControl1_MainPage.ExtractionResult.GetTableFieldValueByTableName("Invoice Items")(0)(0).Value
    Where (0)(0) represents the cell at the intersection of the first column and the first row of the Invoice Items table.
Refer to Document Understanding documentation for each class definition and properties.
Writing data
To edit the values inside the Validation Control, use the Set Variable Value activity and reference the variable:
  • Setting a field value in the To variable field
    VarValidationControl1_MainPage.Field("Patient Name").Value
    Set value field: John Doe.
  • Setting focus on a table cell value
    VarValidationControl1_MainPage.Field("Invoice Items").Field("Description", 0).SetFocus = trueVarValidationControl1_MainPage.Field("Invoice Items").Field("Description", 0).SetFocus = true
    Where ("Description", 0) represents the cell at the intersection of the "Description" column and the first row of the Invoice Items table.
  • Setting confidence or confirm flags
    VarValidationControl1_MainPage.Field("Patient Name").Confidence = 0.95
    VarValidationControl1_MainPage.Field("Patient Name").Confirm = trueVarValidationControl1_MainPage.Field("Patient Name").Confirm = true
  • Updating a multi-value field
    VarValidationControl1_MainPage.Field("Diagnosis Code", 2).Value = "E11.9"
    Where 2 represents the row number in the Diagnosis Code column.
  • Deleting a field value
    VarValidationControl1_MainPage.Field("Vendor Name").DeleteValue
  • Updating a table cell
    VarValidationControl1_MainPage.Field("Invoice Items").Field("Description", 0).Value = "50.00"
  • Variable properties
  • Reading data
  • Writing data
