studio-web
Studio Web for Automation Suite User Guide
Last updated Nov 11, 2025
Page Container
Use the Page Container control to add another App page within the current page.
General
  • Page - The page to import within this control.
  • Hidden- If true, hides the control at runtime.
  • Disabled - If true, disables the control at runtime.
Events
  • Clicked on - Configure what happens when the control is clicked.
Style
  • Control Alignment - By default, inherits the parent alignment. A different alignment other than the parent can be set. To default back to the parent alignment, deselect the overridden options.
    Note: The alignment is dependent on the layout selected for the parent (Vertical vs Horizontal).
  • Border - The border for the control. Border Thickness, Color, and Radius can be configured.
  • Margin- The margin of the layout. By default, a margin of 0px is set. Top/Bottom and Left/Right margin properties are combined. These properties can be detached using the Link button at the right side of the Margin section.
  • Padding - The padding of the layout. By default, a padding of 0px is set. Top/Bottom and Left/Right margin properties are combined. These properties can be detached using the Link button at the right side of the Padding section.
    Border - Sets the border for the container. Border Thickness, Border Color, and Corner Radius can be configured for the border.
  • Padding - The padding of the layout. By default, a padding of 4px is set. Top/Bottom and Left/Right margin properties are combined. These properties can be detached using the Link button at the right side of the Padding section.
  • Size - The width and height of the layout. By default, the Width is set to 100% , while the Height is set to auto. To set minimum or maximum values, click the three dot icon (...).
    Important: Referencing the same page within the page where the Page container control is placed creates a circular reference and crashes the app at runtime.
VB properties
VB property
Data type
Hidden
Boolean
Disabled
Boolean
  • General
  • Events
  • Style
  • VB properties
