studio-web
Studio Web user guide
Last updated Mar 20, 2026
Set an external context using query parameters
You can set an external context to your app. This is especially helpful when starting the app from within a robotic process automation (RPA) process, or if you want your app to have a particular behavior only in a certain context. You can set the external context in two ways: when debugging your app or after publishing your app.
Test an external context while debugging an app
If you want to test how your app works with an external context, you can do this while debugging the app.
  1. Enable query parameters in your app:
    1. Open a new or existing app.
    2. In the Project Explorer, select your app.
    3. In the Properties panel, select the Enable query parameters option.
  2. Configure a control to reference your query parameter:
    1. Select the Toolbox menu.
    2. In the Display section**,** select Label and drag it into your app. The Properties panel opens.
    3. In the Text field, select the Open resources for Text button.
    4. Select Expression editor.
    5. Add App.QueryParam("name"), then select Save.
  3. Debug your app and specify a query parameter:
    1. Select Debug on cloud or Debug step-by-step to begin debugging your app. The Enter query parameter window opens.
    2. In the String query parameter field, add a string, such as this placeholder: name=john
When you debug the app, the Label displays the text specified using the query parameter name.
Set an external context after publishing an app
Once you deployed the app, you can set a query parameter at the end of the URL of the deployed app.
Add the query parameter after the &uts=true part at the end of the URL, with an additional & symbol, as in the following example: &uts=true&name=john. The behavior is the same regardless of how you add the query parameter.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
