document-understanding
Document Understanding User Guide
Last updated Oct 31, 2025
Use the Framework
As a Studio workflow, you could use the Document Understanding™ Process: Studio Template.
Use Form Extractor, Intelligent Form Extractor, and Intelligent Keyword Classifier
Select the workflow in the framework, and replace the endpoint per instruction here and add the Document UnderstandingTM license key.
  • Endpoint: the public URL from Access to the models
  • ApiKey: copy it from Automation Suite (Admin > Licenses > Robot & Services > Document Understanding)
Run the workflow. The robot will process the documents one by one. When the Validation Station pops up, select OK to test if the workflow is running properly.
Use custom Machine Learning Extractor
Select the workflow in the framework and replace the endpoint with the public ML Skill endpoint from the deployed ML package following the instruction here and add the Document Understanding license key.
  • Endpoint: the public ML Skill endpoint from Deploy an out-of-the-box ML Package
