- Overview
- Quickstart Tutorials
- Framework Components
- ML Packages
- Pipelines
- Document Manager
- OCR Services
- Document Understanding deployed in Automation Suite
- Install and use
- First run experience
- Deploy UiPathDocumentOCR
- Deploy an out-of-the-box ML package
- Offline Bundles 2022.10.0
- Offline Bundles 2022.10.2
- Offline Bundles 2022.10.4
- Offline Bundles 2022.10.6
- Offline Bundles 2022.10.8
- Offline bundles 2022.10.9
- Offline Bundles 2022.10.10
- Offline bundles 2022.10.11
- Offline bundles 2022.10.12
- Offline bundles 2022.10.13
- Offline bundles 2022.10.14
- Offline bundles 2022.10.14+patch1
- Use Document Manager
- Use the Framework
- Document Understanding deployed in AI Center standalone
- Deep Learning
- Licensing
- References
- UiPath.Abbyy.Activities
- UiPath.OCR.Activities
- UiPath.OCR.Contracts
- UiPath.OmniPage.Activities
- UiPath.PDF.Activities
Document Understanding User Guide
Use the Framework
linkAs a Studio workflow, you could use the .
Use Form Extractor, Intelligent Form Extractor, and Intelligent Keyword Classifier
linkDouble click the workflow in the framework, and replace the endpoint per instruction here and add the Document UnderstandingTM license key.
- Endpoint: the public URL from Access to the models
- ApiKey: copy it from Automation Suite
(Admin > Licenses > Robot
& Services > Document
Understanding)
Run the workflow. The robot will process the documents one by one. When the Validation Station pops up, click OK to test if the workflow is running properly.
Use custom Machine Learning Extractor
linkDouble click the workflow in the framework and replace the endpoint with the public ML Skill endpoint from the deployed ML package following the instruction here and add the Document Understanding license key.
- Endpoint: the public ML Skill endpoint from Deploy an out-of-the-box ML Package
ApiKey: copy it from Automation Suite (Admin > Licenses > Robot & Services > Document Understanding)
