- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
Automation Suite release notes
Release date: September 24, 2025
The Automation Suite support bundle tool now collects AI Units usage metrics if you use AI Center.
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
- We have fixed an issue that caused the temporary registry installation to fail with a timeout error when connecting to
registry-1.docker.io
. - We have fixed an issue that prevented log forwarding when using S3 endpoints in non-AWS format (that is, without
.amazonaws.com
in the URL), as the endpoint was not in the format expected by Fluentd. - We have fixed an issue causing a delay in Kerberos keytab rotation, which prevented immediate regeneration of authentication tokens and occasionally disrupted database connectivity for services.
- We have fixed an issue where the
uipathctl config tls-certificates
command did not update the registry certificates in ArgoCD for the in-cluster registry in offline scenarios. - An issue prevented the required pods from being created when enabling GPU after adding a GPU node. This issue occurred only when using external registries with project names ( such as Harbor). We have fixed the issue.
- An issue prevented the installer from setting the
storage.useClientID
parameter when you selected a user-assigned managed identity for object storage. As a result, Orchestrator did not use your configured client ID, and in environments where access was restricted to user-assigned managed identities, Orchestrator could not start. We have fixed the issue. - We have fixed an issue that prevented garbage collection from running during in-cluster registry cleanup.
- An issue caused the Thanos compactor to stop metrics block compaction in the object store due to a race condition in Prometheus. This led to increased storage usage in the Ceph bucket. We have fixed the issue.
- An issue caused the pre-upgrade process to stall when deleting the
rook-ceph-object-store
application. This issue occurred due to theCephObjectStore
resource not finalizing, which prevented completion of the upgrade workflow. We fixed the issue.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2024.10.5.
Legend:
- This Automation Suite version bundles a new version of the product. New release notes are available.
- This Automation Suite version bundles a previously released version of the product. No new release notes are available.
Product | Product version | Release status | Release notes |
Action Center | 2024.10.5 |
| Action Center release notes |
AI Center | 2024.10.5 |
| AI Center release notes |
AI Computer Vision | N/A |
| N/A |
Apps | 2024.10.5 |
| Apps release notes |
Automation Hub | 2024.10.5 |
| Automation Hub release notes |
Automation Ops | 2024.10.5 |
| Automation Ops release notes |
Data Service | 2024.10.5 |
| Data Service release notes |
Document Understanding | 2024.10.5 |
Insights | 2024.10.6 |
| Insights release notes |
Orchestrator | 2024.10.8 |
| Orchestrator release notes |
Process Mining | 2024.10.5 |
| Process Mining release notes |
Task Mining | 2024.10.5 |
| Task Mining release notes |
Test Manager | 2024.10.5 |
| Test Manager release notes |
Internal third-party component versions
This Automation Suite release bundles the following internal components:
Component | Version |
RKE2 | 1.33.2+rke2r1 |
ArgoCD | v3.0.11 |
gatekeeper | 3.20.0 |
rook | 1.17.6 |
ceph | 19.2.3 |
prometheus-pushgateway | v3.4.1 |
cert-manager | v1.18.2 |
kube-logging/logging-operator | 6.0.1 |
kube-logging/config-reloader | 6.0.1 |
istio | 1.26.3 |
velero | 1.16.1 |
reloader | v2.2.0 |
Prometheus | v3.5.0 |
Grafana | 12.0.2 |
redis-operator | v7.22.0-15 |
redis-cluster | v7.22.0-216.focal |
oauth2-proxy | v7.11.0 |
