- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
Automation Suite release notes
Release date: November 11, 2024
Full migration is now supported in Automation Suite 2024.10.0.
Compared to the full migration steps in Automation Suite 2023.10, in this version there is an additional migration step in which you can update the schema of the Insights and Orchestrator databases after previously restoring them.
UiPath.OrganizationMigrationApp tool:
- We provide an inner exception during a database connection test for enhanced error logging and debugging.
- We improved the merging process of single sign-on users (SSO) from multiple organizations to handle database conflicts more efficiently. The update also provides accurate migration success messages and prevents potential data duplication. This enhancement significantly benefits organizations utilizing the MSI to Automation Suite setup with a multi-tenant configuration and SSO.
For more details, refer to Performing a full migration.
Introducing Automation Suite on OpenShift
Ever since we released the first Automation Suite flavor, it has been our priority to make the UiPath® automation platform available on the widest possible array of environments. The next step on this journey is Automation Suite on OpenShift, which allows you to deploy the UiPath® platform on the popular OpenShift Container Platform from Red Hat. The new offering is the third Automation Suite flavor we make available, in addition to Automation Suite on Linux and Automation Suite on EKS/AKS. For a summary and comparison of the architecture, features, deployment scenarios, etc. specific to each Automation Suite flavor, see Cross-deployment model feature comparison.
In addition to providing its own Kubernetes solution, OpenShift offers a rich ecosystem that includes its own service mesh, GitOps tool, objectstore, cache, and so much more, delivering a unified, seamless customer experience.
Automation Suite on OpenShift products
- Action Center (Actions and Processes)
- AI Center (AI Center connected to an external Orchestrator not supported)
- Apps
- Automation Hub
- Automation Ops
- Data Service
- Document Understanding AI Center-based projects
- Insights
- Orchestrator
- Process Mining
- Test Manager
Some Automation Suite products have additional dependencies on each other. For details, see Cross-product dependencies.
Installation experience
uipathctl tool for all the major tasks
related to pre-installation, installation, cluster administration, etc. For an
in-depth look at the uipathctl capabilities, see the uipathctl Reference Guide.
input.json cluster configuration file. You can edit the file
using one of the following methods:
For full control over all the parameters and values, edit the
input.jsonfile manually. -
To simplify the sometimes challenging task of editing multiple parameters and flags, use the Automation Suite Installer Wizard.
input.json file for you.
As the tool is in public preview, some complex configuration scenarios might not yet be covered. We eagerly invite you to experiment with the wizard and share your feedback to help us improve this feature. For details, see Generating the configuration file using a GUI-based wizard.
For a quick look at the Automation Suite installation prerequisites, see Prerequisites at a glance.
For Automation Suite installation instructions, see Installing Automation Suite.
Migration options
You can migrate standalone UiPath® products to Automation Suite on OpenShift, with support for single-tenant migration. For details, see Single-tenant migration.
Migrate from Automation Suite on Linux to a new installation of Automation Suite on Automation Suite on OpenShift;
Migrate from Automation Suite on EKS/AKS to a new installation of Automation Suite on OpenShift;
Migrate from Automation Suite on OpenShift to a new installation of Automation Suite on EKS/AKS
For details, see Migrating between Automation Suite clusters.
Migrating from Automation Suite on Linux to an existing installation of Automation Suite on OpenShift;
Migrating an Automation Suite on OpenShift cluster to another Automation Suite on OpenShift cluster.
Shared cluster support
You can deploy Automation Suite either on a dedicated, newly provisioned OpenShift cluster or on a existing cluster, which Automation Suite can share with your other software deployments. A shared cluster deployment can reduce the total cost of ownership and bring you more flexibility.
While deploying Automation Suite on a dedicated cluster involves running the Automation Suite installer with admin privileges, a shared cluster deployment enables you to complete the installation process without granting admin privileges to the Automation Suite installer. Running the installer without admin privileges enhances the security of your deployment by allowing you to adopt industry-wide security practices such as the principle of least privilege, which enables you to meet stringent governance standards.
How to navigate the docs
Here are some tips and tricks on navigating the Automation Suite docs:
The Automation Suite Release Notes are split into three sections, each for an Automation Suite flavor.
Each Automation Suite flavor has a dedicated installation guide: Automation Suite on Linux Installation Guide, Automation Suite on EKS/AKS Installation Guide, and Automation Suite on OpenShift Installation Guide.
The Automation Suite Admin Guide, Automation Suite API Guide, and uipathctl Reference Guide are shared between all the Automation Suite flavors, with all the content being identical.
Support for OpenShift Redis Community Operator
Erratum - added February 17, 2025: We have introduced support for OpenShift Redis Community Operator by OpsTree Solutions. However, we recommend the use of OpenShift Redis Enterprise Operator.
For more details on the OpenShift Redis Community Operator supported versions, see Compatibility matrix.
Log streaming does not work in proxy setups
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2024.10.4.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Service disruptions due to automatic secret rotation
Erratum - added May 14, 2025: An issue causes service disruptions due to the automatic secret rotation, making services temporarily inaccessible.
To address this issue, take the following steps:
Restart the affected service to restore its normal functionality.
Navigate to the ArgoCD UI and from the platform applicatio, select Details > Parameters. Edit the values to add
"secretRotation: enabled: false"underidentity-service. You must take this step after each Automation Suite upgrade or reinstallation.
For AI Center, all skills must be stopped and started from AI Center UI.
Orchestrator and AI Center require SQL Sever version 2019 and higher
Erratum - added February 27, 2025: For this version of Automation Suite, you need to use SQL Server version 2019 or higher for proper operation of Orchestrator and AI Center.
Document Understanding limitations
In this release, Document Understanding modern projects are not supported in Automation Suite Openshift environments.
Full migration from standalone products to Automation Suite not supported
You cannot currently perform a full migration from standalone products version 2024.10 to Automation Suite 2024.10 using the UiPath.OrganizationMigrationApp tool. We are actively working on introducing support for this scenario.
In the meantime, you can perform a single-tenant migration. For details on this migration option, refer to Single tenant migration.
Migration from Automation Suite on Linux to Automation Suite on OpenShift not supported
Erratum - added December 18, 2024: You cannot currently perform a migration from Automation Suite on Linux to Automation Suite on OpenShift. We are actively working on introducing support for this scenario.
No FIPS 140-2 support for Insights
Insights is not supported on FIPS 140-2. If you install Automation Suite on FIPS 140-2-enabled machines, you must disable Insights.
For details on FIPS 140-2, see Security and compliance.
Custom security context requirement for Insights
Insights requires a custom security context to run on Automation Suite on OpenShift. For details, see Configuring the Insights custom security context.
Installation issue when using SQL Server 2017 or older
Erratum - added December 18, 2024: Using SQL Server 2017 (14.x) or older causes an Automation Suite installation issue due to the resource catalog service not supporting SQL Server versions prior to 2019 (15.x). We fixed the issue in Automation Suite 2024.10.1.
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
- Support for full migration
- What's new
- Introducing Automation Suite on OpenShift
- Support for OpenShift Redis Community Operator
- Known issues
- Log streaming does not work in proxy setups
- Licensing SQL connection error
- Service disruptions due to automatic secret rotation
- Orchestrator and AI Center require SQL Sever version 2019 and higher
- Document Understanding limitations
- Full migration from standalone products to Automation Suite not supported
- Migration from Automation Suite on Linux to Automation Suite on OpenShift not supported
- No FIPS 140-2 support for Insights
- Custom security context requirement for Insights
- Installation issue when using SQL Server 2017 or older
- Bundling details
- Product versions
