Last updated Oct 24, 2025
Quick links
Before you begin
Step
Details
Find out the essentials on Disaster Recovery - Active/Passive deployments
Learn more on the architecture of Disaster Recovery - Active/Passive deployments
Frequently asked questions
Installing a new Automation Suite setup
Step
Details
Install the primary server
Generate the input.json file using the interactive installer.
Update the input.json file.
Resume the installation.
Install the secondary server
Copy or generate the input.json from the primary server.
Note:
For Active/Passive configurations, make sure to switch off the products in the passive cluster. For details, see Switching off inactive products.
Converting an existing setup
Step
Details
Converting an existing installation to a Disaster Recovery - Active/Passive setup
Convert the standalone Automation Suite cluster into the primary cluster
Install secondary Automation Suite cluster.
Switching to the secondary cluster
N/A
Upgrading an Active/Passive deployment
N/A
Backing up and restoring an Active/Passive deployment
N/A
  • Before you begin
  • Installing a new Automation Suite setup
  • Converting an existing setup
