Last updated Nov 13, 2025
Migration prerequisites
Before starting the migration, make sure you meet the following prerequisites:
.NET Runtime 6.0
.NET Runtime 6.0 or later is required to run the UiPath.OrganizationMigrationApp tool. You must download and install it before running UiPath.OrganizationMigrationApp.
Linux
If .NET Runtime 6.0 or later is not present, download and install .NET Runtime for Linux before using UiPath.OrganizationMigrationApp.
To install .NET Runtime 6.0 on RHEL, run the following command:
sudo yum install dotnet-sdk-6.0 -ysudo yum install dotnet-sdk-6.0 -y
Windows
The UiPath.OrganizationMigrationApp tool requires .NET Runtime 6.0 at a minimum. If .NET Runtime 6.0 and beyond is not present, download and install .NET Runtime 6.0 for Windows before using UiPath.OrganizationMigrationApp.
Docker/Podman
To complete the migration process, you must use a Docker or Podman client that has been authenticated with the private registry. This allows the migrators to run on the MSI databases, making them compatible with the Automation Suite databases.
Docker
  • To download the Docker binaries, refer to the Install Docker Engine official documentation.
  • To authenticate the Docker registry, refer to the docker login official documentation. Alternatively, you can use the following command by replacing the sample credentials with your actual registry credentials:
    docker login my.registry.io:443 --username "admin" --password "secret"docker login my.registry.io:443 --username "admin" --password "secret"
Podman
  • To download the Podman binaries, refer to the official Podman Installation Instructions.
  • To authenticate to the Podman registry, refer to the Podman login official documentation. Alternatively, you can use the following command by replacing the sample credentials with your actual registry credentials:
    podman login my.registry.io:443 --username "admin" --password "secret"podman login my.registry.io:443 --username "admin" --password "secret"
Orchestrator bucket creation setting
To ensure that Orchestrator buckets are automatically created with the correct CORS policy, you must run the following command. The command requires the jq utility to be installed on your machine.
cd <AS install directory>
rm -f values.json && rm -f appsettings.json
kubectl -n <uipath> get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jq '.' > values.json
jq '.AppSettings' values.json > appsettings.json
jq '.["Storage.CreateBucket.OnTenantCreation.Enabled"] = "true"' appsettings.json > temp.json && mv -f temp.json appsettings.json
uipathctl config orchestrator update-config --app-settings appsettings.jsoncd <AS install directory>
To install jq, use one of the following options:
  • Option 1: Run the following command:
    yum install -y epel-release yum install -y jqyum install -y epel-release yum install -y jq
  • Option 2: Run the following commands:
    shell
    curl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm
    yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpmshell
Warning: Failing to enable the Orchestrator setting that ensures buckets are automatically created with the correct CORS policy causes issues with downloading from storage buckets, which you must address by making manual updates to the CORS policy.
To confirm that the setting has been enabled, run the following command:
kubectl -n <uipath> get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jqkubectl -n <uipath> get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jq
If the setting has been enabled, the command should return the following response:
  "AppSettings": {
    "Storage.CreateBucket.OnTenantCreation.Enabled": "true"
  "AppSettings": {
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To download UiPath.OrganizationMigrationApp, see Downloading the installation packages.
To see which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
Tool for managing Microsoft SQL Server
You must download and install SQL Server Management Studio (SSMS) or a similar tool for managing Microsoft SQL Server. This tool helps you restore the Orchestrator database to the Automation Suite SQL Server instance or a different SQL Server instance.
  1. Download and install SQL Server Management Studio.
  2. Log into the standalone SQL Server using the standalone SQL connection string.
  3. Open port 1433 for the source and target database.
Special character escape rules for connection string passwords
In most instances, connection passwords are encapsulated within a single quotation mark ('). However, when the password includes special characters such as ` or $, a different approach is required.
In these cases, the password must be formatted as \`"<password>\`", replacing <password> with the actual password. Moreover, you must also adhere to the escape rules as detailed in the following table:
Original format in ADUC
Escaped format in PowerShell string
cn=James $ Smith
"cn=James `$ Smith"
cn=Sally Wilson + Jones
"cn=Sally Wilson \+ Jones"
cn=William O'Brian
"cn=William O'Brian"
cn=William O`Brian
"cn=William O``Brian"
cn=Richard #West
"cn=Richard #West"
cn=Roy Johnson$
"cn=Roy Johnson$"
Example
Assume that the original password is 7'8:<=XMe$y[@vC?_4ZeY8c-~y'W!1dU4gnczuf'/p>j<I. Adhering to the special character escape rules, it becomes: Password=\`"7'8:<=XMe`$y[@vC?_4ZeY8c-~y'W!1dU4```gnczuf'/p>```j<I\`".
The full command, with the password configured in destination connection string, looks as follows:
./UiPath.OrganizationMigrationApp.exe migrate -a -m -s "Server=tcp:abc.com,1433;Initial Catalog=UiPath_20230531;Persist Security Info=False;User ID=username;Password=asiodhyf;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;" -d "Server=tcp:cde.net,1433;Initial Catalog=AutomationSuite_Platform;Persist Security Info=False;User [email protected];Password=\`"7'8:<=XMe`$y[@vC?_4ZeY8c-~y'W!1dU4```gnczuf'/p>```j<I\`""./UiPath.OrganizationMigrationApp.exe migrate -a -m -s "Server=tcp:abc.com,1433;Initial Catalog=UiPath_20230531;Persist Security Info=False;User ID=username;Password=asiodhyf;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;" -d "Server=tcp:cde.net,1433;Initial Catalog=AutomationSuite_Platform;Persist Security Info=False;User [email protected];Password=\`"7'8:<=XMe`$y[@vC?_4ZeY8c-~y'W!1dU4```gnczuf'/p>```j<I\`""
Note: Ensure that the command only gets executed on a machine that has authorized access to the RDS database.
Administrator group configuration requirement
Before starting the migration, you must add the Administrator group in every tenant.
If you are performing an organization merge and the Administrator group is not added in all tenants, you can lock yourself out of the Orchestrator instance after the merge completes.
Adding the Administrator group in each tenant ensures that administrative access is preserved throughout the migration and merge process.
