- Overview
- Requirements
- Pre-installation
- Migration and upgrade- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting- Installation fails when Velero is enabled
- Issue with connecting to the Multi-AZ database server
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Oct 24, 2025
To fix the issue, take the following steps:
                     Make sure Helm 3.14 runs on the jumpbox or laptop used for installing Automation Suite.
                     Extract the configuration values of the failed Helm chart, which in this case is Velero: helm -n velero get values velero > customvals.yamlhelm -n velero get values velero > customvals.yaml
                     Add the missing image pull secret in thecustomvals.yamlfile, under the.image.imagePullSecretspath:image: imagePullSecrets: - uipathpullsecretimage: imagePullSecrets: - uipathpullsecret
                     If Velero has already been installed, uninstall it: helm uninstall -n velero velerohelm uninstall -n velero velero
                     Create a new file calledvelerosecrets.txt. Populate it with your specific information, as shown in the following example:AZURE_CLIENT_SECRET=<secretforserviceprincipal> AZURE_CLIENT_ID=<clientidforserviceprincipal> AZURE_TENANT_ID=<tenantidforserviceprincipal> AZURE_SUBSCRIPTION_ID=<subscriptionidforserviceprincipal> AZURE_CLOUD_NAME=AzurePublicCloud AZURE_RESOURCE_GROUP=<infraresourcegroupoftheakscluster>AZURE_CLIENT_SECRET=<secretforserviceprincipal> AZURE_CLIENT_ID=<clientidforserviceprincipal> AZURE_TENANT_ID=<tenantidforserviceprincipal> AZURE_SUBSCRIPTION_ID=<subscriptionidforserviceprincipal> AZURE_CLOUD_NAME=AzurePublicCloud AZURE_RESOURCE_GROUP=<infraresourcegroupoftheakscluster>
                     Encode thevelerosecrets.txtfile:export b64velerodata=$(cat velerosecrets.txt | base64)export b64velerodata=$(cat velerosecrets.txt | base64)
                     Create thevelero-azuresecret in theveleronamespace. Include the following content:apiVersion: v1 kind: Secret metadata: name: velero-azure namespace: velero data: cloud: <put the $b64velerodata value here>apiVersion: v1 kind: Secret metadata: name: velero-azure namespace: velero data: cloud: <put the $b64velerodata value here>
                     Reinstall Velero: helm install velero -n velero <path to velero - 3.1.6 helm chart tgz> -f customvals.yamlhelm install velero -n velero <path to velero - 3.1.6 helm chart tgz> -f customvals.yaml
