Automation Suite release notes
Last updated Dec 4, 2025
Release date: November 6, 2025
This release brings security updates to address CVE-2025-55315.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
| DISCOVER | BUILD | MANAGE | ENGAGE |
| Automation Hub 2023.4.12 | Automation Ops 2023.4.12 | AI Center 2023.4.13 | Action Center 2023.4.13 |
| Task Mining 2023.4.13 | AI Computer Vision 2023.4.12 | Insights 2023.4.13 | Apps 2023.4.12 |
| Process Mining 2023.4.13 | Document Understanding 2023.4.13 | Orchestrator 2023.4.16 | |
| Test Manager 2023.4.11 | |||
| Data Service 2023.4.13 |
Internal third-party component versions
This Automation Suite release bundles the following internal components:
| Component | Version |
| RKE2 | 1.31.4+rke2r1 |
| ArgoCD | v2.14.4 |
| Grafana | 11.1.0 |
| kube-logging/logging-operator | 5.2.0 |
| kube-logging/config-reloader | v0.0.7 |
| ceph | 19.2.0 |
| rook-ceph | 1.16.1 |
| prometheus-pushgateway | v3.0.0 |
| cert-manager | v1.17.1 |
| rancher-istio | 105.4.0-up1.23.2 |
| rancher-gatekeeper | 104.0.1-up3.13.0 |
| rancher-monitoring | 105.1.3-up61.3.2 |
| longhorn | 1.7.3 |
| longhorn-crd | 1.1.100 |
| csi-driver-smb | 1.16.0 |
| velero | 1.15.2 |
| redis-operator | v7.8.4-9 |
| redis-cluster | v7.8.4-95.focal |
| oauth2-proxy | v7.8.1 |
