Automation Suite release notes
Release date: November 22, 2023
You can now migrate from a standalone UiPath® product to Automation Suite 2023.4.3 as we have released a new version of the UiPath.OrganizationMigrationApp tool. For more details, see Full migration.
Release date: October 26, 2023
Previously, there was an issue where well-known SIDs were inadvertently included when retrieving security groups, leading to unexpected behavior. Well-known SIDs are no longer included when fetching security groups, ensuring smoother and more predictable functionality.
We have fixed an issue impacting the seamless operation of Orchestrator and AI Center when using an Azure Government storage account as external object store. In Orchestrator, all default packages were missing, whereas in AI Center, the deployment of Custom ML Skills failed.
Erratum - added October 17, 2024
In a proxy environment, if the proxy server uses the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods cannot communicate with the FQDN. The issue causes the following error:System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.To fix the issue, see Automation Suite on EKS/AKS troubleshooting.
Erratum - added August 14, 2024
For AI Center and Task Mining, theListBucket API
prerequisite check fails when using an external objectstore. However, AI Center and Task Mining do not use theListBucket API
permission. We removed the unnecessary check in Automation Suite 2023.4.8. -
Erratum - added June 25, 2024
Following an Automation Suite on AKS installation or upgrade, the backup setup does not work because of a failure to connect to Azure Government. You can fix the issue by taking the steps described in Automation Suite on EKS/AKS troubleshooting.
Erratum: Added April 19, 2024
An upgrade known issue affecting AKS causes Automation Suite to fail. When trying to upgrade AKS, theargocd-redis-ha-server
pod is put in error state. If you encounter this issue, use the workaround documented in the Troubleshooting chapter. The issue no longer occurs in Automation Suite 2023.4.6. -
Erratum: Added November 20, 2023
You cannot forward Fluentd and Fluent Bit logs to Azure and AWS government cloud storage. We recommend using Splunk and forwarding application logs there.
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVER | BUILD | MANAGE | ENGAGE |
AI Center 2023.4.3 | Action Center 2023.4.3 | ||
Task Mining 2023.4.3 | AI Computer Vision 2023.4.3 | Insights 2023.4.3 | Apps 2023.4.3 |
Document Understanding 2023.4.3 | Orchestrator 2023.4.3 | ||
Test Manager 2023.4.3 | |||
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
Component |
Version |
Istio | 1.17.2 (Distroless) |
ArgoCD | v2.5.10 |
Prometheus | v2.39.1 |
Grafana | 9.5.2 |
Fluentd & Fluent-bit |
logging-operator : 4.1.0 logging-operator-logging : 4.1.0 |
Gatekeeper | 3.11.0 |
Cert-Manager | v1.11.2 |
Velero | 3.1.6 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
