- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Orchestrator Pod in CrashLoopBackOff or 1/2 Running With Multiple Restarts
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
If the Orchestrator pod in CrashLoopBackOff or 1/2 is running with multiple restarts, the failure could be related to the authentication keys for the object storage provider, Ceph.
To check if the failure is related to Ceph, run the following commands:
kubectl -n uipath get pod -l app.kubernetes.io/component=orchestratorkubectl -n uipath get pod -l app.kubernetes.io/component=orchestratorIf the output of this command is similar to one of the following options, you need to run an additional command.
Option 1:
NAME READY STATUS RESTARTS AGE
orchestrator-6dc848b7d5-q5c2q 1/2 Running 2 6m1s
OR
Option 2
orchestrator-6dc848b7d5-q5c2q 1/2 CrashLoopBackOff 6 16mOption 1:
OR
Option 2
orchestrator-6dc848b7d5-q5c2q 1/2 CrashLoopBackOff 6 16mVerify if the failure is related to Ceph authentication keys by running the following command:
kubectl -n uipath logs -l app.kubernetes.io/component=orchestrator | grep 'Error making request with Error Code InvalidAccessKeyId and Http Status Code Forbidden' -okubectl -n uipath logs -l app.kubernetes.io/component=orchestrator | grep 'Error making request with Error Code InvalidAccessKeyId and Http Status Code Forbidden' -oIf the output of the above command contains the string
Error making request with Error Code InvalidAccessKeyId and Http Status Code Forbidden, the failure is due to the Ceph authentication keys.
Rerun the
rook-ceph-configure-script-job and credential-manager jobs using the following commands:
kubectl -n uipath-infra get job "rook-ceph-configure-script-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
kubectl -n uipath-infra get job "credential-manager-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
kubectl -n uipath delete pod -l app.kubernetes.io/component=orchestratorkubectl -n uipath-infra get job "rook-ceph-configure-script-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
