- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
In a multi-node HA-ready production setup, High Availability (HA) is enabled by default. However, the Redis-based in-memory cache used by cluster services runs on a single node and represents a single point of failure. Therefore, if you have not purchased a High Availability Add-on (HAA) license, a cache node failure or restart will result in downtime for the entire cluster. To prevent such an incident, you can purchase HAA, which enables redundant, multi-node HA-ready production deployment of the cache.
All installations include the HAA software with a single-node license. This license is free of cost, no purchase required.
If you wish to enable HAA across multiple nodes, then purchasing an HAA license is required. This will implement full high availability for the cluster in a multi-node HA-ready production setup.
HAA is based on Redis technology.
To do that, take the following steps:
- Purchase an HAA license. Contact UiPath for details.
Update the following fields in the
cluster_config.jsonfile:fabric.redis.license- enter the HAA license converted to a single base64 string. In bash you can do that usingecho 'license_text_here' | base64 -w0.-
fabric.redis.ha- usetrueto enable HAA and make sure to also configure thefabric.redis.licenseparameter. This enables HAA database replication and increases the number of HAA pods to 3. By default,fabric.redis.hais set tofalse.Note: Ifredis.hais enabled,redis.licenseneeds to be set to a license that supports more than two shards."fabric": { "redis": { "ha": "true", "license": Base64String } }"fabric": { "redis": { "ha": "true", "license": Base64String } }
- Rerun the fabric installer:
online installations:
./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement -
offline installations:
./install-uipath.sh -i cluster_config.json -f --install-type offline -o output.json --accept-license-agreement./install-uipath.sh -i cluster_config.json -f --install-type offline -o output.json --accept-license-agreement
