- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
MongoDB Monitoring Dashboard
linkBackground Information
linkMongoDB monitoring dashboard is a Grafana dashboard for monitoring MongoDB resources and health in the Automation Suite environment.
Note: You cannot bring your own MongoDB.
Prerequisites
linkBefore you start, download the MongoDB Monitoring Dashboard 2021.10.1 file from here. After clicking on the download link, the JSON file will open in your browser. To download the file to your local drive, right-click on the page and click Save as....
Adding the Dashboard to Grafana
link- Open the Grafana portal.
- Sign in using your credentials.
- Click on the
symbol on the left and then on Create.
- Select Import from the menu.
- Click on Upload JSON file.
- Select the downloaded JSON file.
- Click on Import.
Procedure Results
linkOnce the procedure is done, the MongoDB Monitoring dashboard will open. Once loaded, the dashboard can be viewed at any time by searching the dashboard by name. To do so, use the :mag: Search button on the left.
