Automation Hub User Guide
Last updated Jun 26, 2025
Starting as a Program Manager
After successfully logging in, you, as a Program Manager, need to access Workspace > Automation Pipeline in order to decide what ideas should progress in the implementation phases. Furthermore, you can check out and edit any information from the page as well as assign implementation teams for the shared ideas.
You are encouraged to Share Ideas and upload Components that will boost the company’s RPA assimilation.
Apart from the Automation Pipeline page, you can check out all the other options available under the Workspace Overview module if you want to have a detailed view over:
