Automation Hub User Guide
Last updated Jun 26, 2025
Automation Hub Policy in Automation Ops
Verifying Policy Versions
Before creating a new policy, make sure you're using the latest policy versions for applications. Do this by following the steps below:
  1. In Automation Ops > Gouvernance, select Settings.
  2. Select a 22.10 or higher version for Studioor StudioX and select Save.
Creating a New Product Policy
To add a new product policy, follow the steps below:
  1. In Automation Ops > Governance, select Add Product Policy.
  2. Select Studio or StudioX, input a Name to your policy, and select Add.
    Note: If you want to enforce the analyzer, activate the Enforce Analyzer before Publish setting in the Designsection.
  3. Select Workflow Analyzer tab and scroll down until you find the ST-USG-034 Rule ID.
  4. Select the Editicon.
  5. Check the Is enabled box to activate the rule and select Save.
Deploying a Policy Rule
  1. In Automation Ops > Governance, select Deployment.
  2. In the Users tab, select the Editicon beside your User Name.
  3. Make sure that for the Studio, the newly created policy is selected.
    Tip: To learn more about governance deployment check Deploy Governance Policies article.
    Note: If you can't find your user in the list, select Deployment for User, to create one.
Below is a video representation of the process:
  • Verifying Policy Versions
  • Creating a New Product Policy
  • Deploying a Policy Rule
