- Open API- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
The Open API feature allows Automation Hub users to access and manipulate their tenant data programmatically. Based on the feedback received, as well as the platform structure, we've focused on delivering the following API requests:
Customized Assessments
               GET/idea-schema
               POST/idea-from-schema
               GET/automations/{automationId}/schema
               PATCH/automations/{automationId}
Automation Ideas
               GET/automations
               GET/automations/collaborators
               DELETE/automations/{automationId}/collaborators
               POST/automations/{automationId}/collaborators
               GET/automations/{automationId}/documents
               POST/automations/{automationId}/documents
               GET/automations/{automationId}/components
               GET/questionnaire
               GET/cba
               PUT/automations/cba/{automationId}/project-plan-baseline
               POST/automationidea
               POST/coe-automationidea
               POST/processmining-idea
               POST/automations/{automationId}/media
               POST/automations/status
               POST/automations/{automationId}/tags
               PUT/automation/{automationId}/categories
Automation Pipeline
               GET/automationpipeline
Users
               GET/users
               GET/roles
               POST/adduser
               POST/edituser
Application Inventory
               GET/appinventory
               PUT/appinventory
               DELETE/appinventory/{applicationId}
Categories
               GET/hierarchy
               PUT/categories
Components
               GET/components
Automation Store
               GET/automation-store
               GET/automation-store/{automationId}/reviews
More field examples and API calls can be found in Swagger documentation.
These API calls reflect all the actions that a user can perform in the Automation Hub interface.
In order to start making calls with the following variables access the Open API options from the Automation Hub platform > Admin Console > Platform Setup > Open API and generate your token.
| Variable | Value |
| Token | The token generated from the Automation Hub UI. |
| URL | https://{yourDomain}/automationhub_/api/v1/openapi |
| Delayed Release URL | http://ah-gxp-openapi-us.uipath.com/api/v1/openapi/ |
| GET all ideas API structure for Delayed Release Organizations | http://ah-gxp-openapi-us.uipath.com/api/v1/openapi/automations |
| App key | The app key generated from the Automation Hub UI. |
The next step is to Consume the available APIs.
Check out the Logical Resources and the Available Operations.
When building your API request always rely on the Input Dictionary as it contains all the query parameters you will be using.
