- Open API
- Introduction to Automation Hub API
 - API References
 - Generate your Token from Automation Hub
 - Input for Automation Pipeline
 - Input for Submission Type
 - Input for Phase
 - Input for Status
 - Input for Phase and Status Update
 - Input for Business Unit
 - Input for Applications
 - Input for Category
 - Input for Cost Benefit Analysis
 - Input for High Level Assessment
 - Input for Detailed Assessment
 - Input for Automation Idea Creation Date
 - Input for Users
 - Input for User Status
 - User Status Table
 - Input for Collaborators
- Output Dictionary
 - Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
Last updated Apr 19, 2024
Note: For the POST call made to update an idea phase and status do not use the phase or status keys.
                         Key  |
                         Phase name  |
                         Phase ID  |
                         IDEA  |
                         Idea  |
                         1  |
                         ASSESSMENT  |
                         Assessment  |
                         2  |
                         QUALIFICATION  |
                         Qualification  |
                         3  |
                         ANALYSIS  |
                         Analysis  |
                         4  |
                         SOLUTION_DESIGN  |
                         Solution Design  |
                         5  |
                         DEVELOPMENT  |
                         Development  |
                         6  |
                         TESTING  |
                         Testing  |
                         7  |
                         HYPERCARE  |
                         Hypercare  |
                         8  |
                         LIVE  |
                         Live  |
                         9  |
                         BUSINESS_REVIEW  |
                         Business Review  |
                         10  |
                         TECHNICAL_REVIEW  |
                         Technical Review  |
                         11  |
Example: phase=2
UI Correspondent:
Automation Phase and Status
