Automation Hub API Guide
Last updated Apr 19, 2024
Input for Automation Idea Creation Date
Note:
For both Automation Idea Creation Date and Automation Idea Update Date filters the used date format is EPOCH.
Key
Value
Use Case
createdStart
The start date for the search.
GET filter
createdEnd
The end date for the search.
GET filter
Examples:
  • Retrieve all Automation Ideas created after 23/07/2020:
    createdStart=1595462400
  • Retrieve all Automation Ideas created before 23/07/2020:
    createdEnd=1595462400
  • Retrieve all Automation Ideas created between 22/07/2020 and 23/07/2020:
    CreatedStart=1595376000&createdEnd=1595462400
