- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Last updated Nov 13, 2025
To generate the input.json configuration file, take one of the following steps:
- Option A: Generate the latest
input.jsonfile:uipathctl manifest get-revision | Out-File -Encoding ascii input.jsonuipathctl manifest get-revision | Out-File -Encoding ascii input.json - Option B: List all the past
input.jsonfiles and determine which one you want to choose:uipathctl manifest list-revisionsuipathctl manifest list-revisions
- Move the
versions.jsonfile to the same directory asinput.json. You can getversions.jsonfrom the Automation Suite installation folder. - Provide the new connection strings for the installed products.
To provide the restored connection string to the Orchestrator service, add or update
sql_connection_strunderorchestratorin theinput.jsonfile:"orchestrator": { "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true }"orchestrator": { "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true } -
If Test Automation tables are placed inside the standalone Orchestrator database, you can also add the same connection string for Test Automation feature inside the
input.jsonfile:"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchestrator connection string>" }, "sql_connection_str": "<restored orchestrator connection string>", (added line) "enabled": true }"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchestrator connection string>" }, "sql_connection_str": "<restored orchestrator connection string>", (added line) "enabled": true } - To provide the restored connection string to the Insights service, add or update
sql_connection_strunderinsightsin theinput.jsonfile."insights": { "sql_connection_str": "<restored connection string>", (added line) "enabled": true }"insights": { "sql_connection_str": "<restored connection string>", (added line) "enabled": true }
- Update the
input.jsonfile by running the installer.- To migrate Orchestrator only, run the following command:
uipathctl manifest apply input.json --only orchestrator --versions versions.jsonuipathctl manifest apply input.json --only orchestrator --versions versions.json - To migrate Insights only, run the following command:
uipathctl manifest apply input.json --only insights --versions versions.jsonuipathctl manifest apply input.json --only insights --versions versions.json
Note:If you run the command on Windows, replaceuipathctlwith.\uipathctl.exein the command. - To migrate Orchestrator only, run the following command:
- Remap the organization IDs in the Insights tables.
For more details, see Remapping the organization IDs.
