Last updated Nov 13, 2025
Prerequisites at a glance
The following table lists the main hardware and software requirements for deploying Automation Suite on OpenShift.
ComponentPrerequisites
Cluster
OpenShift cluster
Minimum node capacity8 vCPU and 16 GB RAM
Total cluster capacitySee Capacity planning.
Cache
Redis Enterprise
Registry
OCI-compliant registry
SQL Server
  • Microsoft SQL Server 2017, 2019, and 2022; Standard and Enterprise editions
  • 8 (v-)CPU
  • 32 GB RAM
  • 256 GB SSD
Storage
  • Objectstore - Azure Blob, AWS S3, S3-compaMBle Objectstore
  • Block storage (StorageClass with replication for the Persistent Volume)
  • File system (StorageClass for workloads that do not require replication)
TLS
1.2 or 1.3
CertificatesThe certificate for the FQDN to access Automation Suite
ProxyOnly required for proxy configurations
