- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Monitoring and alerting
- Cluster administration
- Troubleshooting
kubeconfig file. Your management machine can run Linux, Windows, or MacOS.
The following tools are required to successfully run the prerequisite checks, installation, and post-installation steps on your cluster via the client machine.
Tool |
Description |
Download |
Required.
uipathctl is a UiPath® command-line tool that allows you to run commands against Automation Suite Kubernetes.
You can use
uipathctl to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI.
For more information, including a complete list of uipathctl operations, see the uipathctl Reference Guide.
| Required. Needed to perform prerequisite checks and installation steps. | |
oc | Optional. Ensure that oc matches the version of your cluster.
as-cmk.tar.gz contains the container images and deployment manifests of UiPath® shared capabilities and UiPath® products.
| Download as-cmk.tar.gz |
openshift.tar.gz |
openshift.tar.gz contains the container images and deployment manifests of UiPath® shared capabilities and UiPath® products.
mirror-registry.sh is required to configure an external Docker registry.
| Download mirror-registry.sh |
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations.
| Download hydrate-registry.sh |
as-images.txt contains the name and version of the container images that you must pull and upload into the external Docker registry.
| Download as-images.txt |
as-helm-charts.txt contain the details for the UiPath® application helm chart that you must pull and upload to an external Docker registry hosted
on your environment.
| Download as-helm-charts.txt |
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands.
| Download uipathtools |
This page provides a list of download links for all the artifacts you may need to install or configure Automation Suite. Make sure to select the version of the artifacts you target.
commands against Automation Suite. You can use uipathctl to check
uipathctl is only compatible with the x86 architecture.
You cannot run uipathctl on machines based on the ARM architecture,
such as Macs with Apple Silicon (M series) CPUs.
2024.10.5
uipathctl for Automation Suite 2024.10.5, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-windows-amd64.tar.gz - MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-darwin-amd64.tar.gz
2024.10.4
uipathctl for Automation Suite 2024.10.4, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gz - MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-darwin-amd64.tar.gz
2024.10.3
uipathctl for Automation Suite 2024.10.3, run one of the following commands, depending on your OS:
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-darwin-amd64.tar.gz
2024.10.2
uipathctl for Automation Suite 2024.10.2, run one of the following commands, depending on your OS:
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-darwin-amd64.tar.gz
2024.10.1
uipathctl for Automation Suite 2024.10.1, run one of the
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-darwin-amd64.tar.gz
2024.10.0
uipathctl for Automation Suite 2024.10.0, run one of the
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-darwin-amd64.tar.gz
2024.10.5
versions.json for Automation Suite 2024.10.5, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.5/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.5/versions.json2024.10.4
versions.json for Automation Suite 2024.10.4, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.4/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.4/versions.json2024.10.3
versions.json for Automation Suite 2024.10.3, run the
following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3/versions.json2024.10.2
versions.json for Automation Suite 2024.10.2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2/versions.json2024.10.1
versions.json for Automation Suite 2024.10.1, run the
following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.1/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.1/versions.json2024.10.0
versions.json for Automation Suite 2024.10.0, run the
following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.0/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.0/versions.jsonoc matches the version of your cluster.
oc, see the OpenShift documentation.
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
2024.10.4
Linux
To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command:
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zip -
Windows
To download UiPath.OrganizationMigrationApp on a Windows machine, access this link.
2024.10.3
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zip -
Windows
2024.10.2
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zip -
Windows
2024.10.1
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zip -
Windows
2024.10.0
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zip -
Windows
as-cmk.tar.gz with openshift.tar.gz.
as-cmk.tar.gz.
as-cmk.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product.
as-cmk.tar.gz is required during installation and upgrade.
2024.10.1
For the checksum file, access this link.
Linux:
To downloadas-cmk.tar.gzon a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-cmk-2024.10.1.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-cmk-2024.10.1.tar.gz -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gzhttps://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gzFor the checksum file, access this link.
Linux:
To downloadas-cmk.tar.gzon a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gz -
Windows:
openshift.tar.gz replaces the as-cmk.tar.gz image used in previous versions.
openshift.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product.
openshift.tar.gz is required during installation and upgrade.
2024.10.5
Linux:
To downloadopenshift.tar.gzon a Linux machine, run the following command:wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.5/openshift-2024.10.5.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.5/openshift-2024.10.5.tar.gz -
Windows:
2024.10.4
Linux:
To downloadopenshift.tar.gzon a Linux machine, run the following command:wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.4/openshift-2024.10.4.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.4/openshift-2024.10.4.tar.gz -
Windows:
2024.10.3
Linux:
To downloadopenshift.tar.gzon a Linux machine, run the following command:wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.3/openshift-2024.10.3.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.3/openshift-2024.10.3.tar.gz -
Windows:
2024.10.2
Linux:
To downloadopenshift.tar.gzon a Linux machine, run the following command:wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.2/openshift-2024.10.2.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.2/openshift-2024.10.2.tar.gz -
Windows:
2024.10.5
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.5/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.5/mirror-registry.sh -
Windows:
To downloadmirror-registry.shon a Windows machine, access this link.
2024.10.4
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.sh -
Windows:
2024.10.3
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.sh -
Windows:
2024.10.2
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.sh -
Windows:
2024.10.1
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.sh -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.shhttps://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh-
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh -
Windows:
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
2024.10.5
Linux:
To downloadhydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.5/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.5/hydrate-registry.sh -
Windows:
To downloadhydrate-registry.shon a Windows machine, access this link.
2024.10.4
Linux:
To downloadhydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.sh -
Windows:
2024.10.3
Linux:
To downloadhydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.sh -
Windows:
2024.10.2
Linux:
To downloadhydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.sh -
Windows:
2024.10.1
Linux:
To downloadhydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.sh -
Windows:
2024.10.0
Linux:
To downloadhydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.sh -
Windows:
as-images.txt contains the name and version of the container images that must be
pulled and uploaded into the external Docker registry.
2024.10.5
Linux
To downloadopenshift-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.5/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.5/openshift-images.txt -
Windows:
To downloadopenshift-images.txton a Windows machine, access this link and rename the file toas-images.txt.
2024.10.4
Linux
To downloadopenshift-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.4/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.4/openshift-images.txt -
Windows:
2024.10.3
Linux
To downloadopenshift-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3/openshift-images.txt - Windows:
To download
2024.10.2
Linux
To downloadopenshift-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2/openshift-images.txt - Windows:
To download
2024.10.1
Linux
To downloadopenshift-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.1/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.1/openshift-images.txt - Windows:
To download
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/openshift-images.txthttps://download.uipath.com/automation-suite/2024.10.0/openshift-images.txt-
Linux
To downloadopenshift-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.0/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.0/openshift-images.txt - Windows:
To download
that must be pulled and uploaded to an external Docker registry hosted on your
environment.
2024.10.5
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-helm-charts.txt -
Windows:
To downloadembedded-helm-charts.txton a Windows machine, access this link and rename the file toas-helm-charts.txt.
2024.10.4
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txt -
Windows:
2024.10.3
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txt -
Windows:
2024.10.2
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txt -
Windows:
2024.10.1
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txt -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txthttps://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt-
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt -
Windows:
capabilities specific to health commands. The tool is backward compatible and works with
any supported Automation Suite version. We recommend using uipathtools
as the first step if you face any issue.
2024.10.5
uipathtools, run one of the following commands, depending on your OS:
- Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-linux-amd64.tar.gz - Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-windows-amd64.tar.gz - MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-darwin-amd64.tar.gz
2024.10.4
- Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gz - Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gz - MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-darwin-amd64.tar.gz
2024.10.3
your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-darwin-amd64.tar.gz
2024.10.2
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-darwin-amd64.tar.gz
2024.10.1
your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-darwin-amd64.tar.gz
2024.10.0
your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-darwin-amd64.tar.gz
- uipathctl
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- versions.json
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- Openshift CLI (oc)
- UiPath.OrganizationMigrationApp
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-cmk.tar.gz
- 2024.10.1
- 2024.10.0
- openshift.tar.gz
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- mirror-registry.sh
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- hydrate-registry.sh
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-images.txt
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-helm-charts.txt
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- uipathtools
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
