Last updated Oct 24, 2025
Step 2: Updating the schema of the restored product database
This section guides you through the process of restoring and updating the Identity and Orchestrator databases using Docker or Podman. To identify the images to use for performing the schema update, refer to the Migration compatibility matrix.
  1. Take the connection string of the restored Identity database and save it in a file, for example cs.txt. Provide sufficient permissions for the file (chmod 666 cs.txt) to be used by the container.
  2. Run the Identity database migrator to update the schema of the restored Identity database. You can do this using either Docker or Podman.
    <podman/docker> run -v <absolute-path-to-cs.txt>:/uipath/secrets/cs.txt <docker-registry>/identity-service-datamigrator:<datamigrator-image-version> /app/UiPath.DataMigrator.Cli.dll install --connectionStringFile /uipath/secrets/cs.txt<podman/docker> run -v <absolute-path-to-cs.txt>:/uipath/secrets/cs.txt <docker-registry>/identity-service-datamigrator:<datamigrator-image-version> /app/UiPath.DataMigrator.Cli.dll install --connectionStringFile /uipath/secrets/cs.txt
    If the command fails with [ERR] File '/uipath/secrets/cs.txt' doesn't exist., it could be due to the SELinux security feature. This could occur if you are using a Linux distribution which has this feature enabled. In this case, you must use this command:
    <podman/docker> run -v <absolute-path-to-cs.txt>:/uipath/secrets/cs.txt:z  <docker-registry>/identity-service-datamigrator:<datamigrator-image-version>  /app/UiPath.DataMigrator.Cli.dll install --connectionStringFile /uipath/secrets/cs.txt<podman/docker> run -v <absolute-path-to-cs.txt>:/uipath/secrets/cs.txt:z  <docker-registry>/identity-service-datamigrator:<datamigrator-image-version>  /app/UiPath.DataMigrator.Cli.dll install --connectionStringFile /uipath/secrets/cs.txt
    Example:
    root@migration-test:~/migration# podman run -v /root/migration/cs.txt:/uipath/secrets/cs.txt  sfbrdevhelmweacr.azurecr.io/identity-service-datamigrator:25.1.22-alpha-k8.19 /app/UiPath.DataMigrator.Cli.dll install --connectionStringFile /uipath/secrets/cs.txt
    [07:29:27 INF] Initializing database connection string from file /uipath/secrets/cs.txt
    [07:29:39 INF] Skip adding data masking for non-cloud deploymentroot@migration-test:~/migration# podman run -v /root/migration/cs.txt:/uipath/secrets/cs.txt  sfbrdevhelmweacr.azurecr.io/identity-service-datamigrator:25.1.22-alpha-k8.19 /app/UiPath.DataMigrator.Cli.dll install --connectionStringFile /uipath/secrets/cs.txt
  3. Take the connection string of the restored Orchestrator database and save it in .json format, for example app-secrets.jsonin the following format:
    { "AppSettings": {}, "ConnectionStrings": {"Default":"<connection-string>"} }{ "AppSettings": {}, "ConnectionStrings": {"Default":"<connection-string>"} }
  4. Run the Orchestrator database migrator to update the schema of the restored Orchestrator database. You can do this using either Docker or Podman.
    <podman/docker> run -v <absolute-path-to-app-secrets.json>:/config/app-secrets/values.json <docker-registry>/orchestrator/orchestrator-tools-sf:<orchestrator-migrator-version> ./UiPath.Orchestrator.Cli.dll database upgrade-database --database-type Default --configuration-path ./UiPath.Orchestrator.dll.config --configPaths /config/app-secrets/values.json --verbose<podman/docker> run -v <absolute-path-to-app-secrets.json>:/config/app-secrets/values.json <docker-registry>/orchestrator/orchestrator-tools-sf:<orchestrator-migrator-version> ./UiPath.Orchestrator.Cli.dll database upgrade-database --database-type Default --configuration-path ./UiPath.Orchestrator.dll.config --configPaths /config/app-secrets/values.json --verbose
    Example:
    root@migration-test:~/migration# podman run -v /root/migration/app-secrets.json:/config/app-secrets/values.json sfbrdevhelmweacr.azurecr.io/orchestrator/orchestrator-tools-sf:24.10.2 ./UiPath.Orchestrator.Cli.dll database upgrade-database --database-type Default --configuration-path ./UiPath.Orchestrator.dll.config --configPaths /config/app-secrets/values.json --verboseroot@migration-test:~/migration# podman run -v /root/migration/app-secrets.json:/config/app-secrets/values.json sfbrdevhelmweacr.azurecr.io/orchestrator/orchestrator-tools-sf:24.10.2 ./UiPath.Orchestrator.Cli.dll database upgrade-database --database-type Default --configuration-path ./UiPath.Orchestrator.dll.config --configPaths /config/app-secrets/values.json --verbose
