- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
kubeconfig
file. Your management machine can run Linux, Windows, or MacOS.
The following tools are required to successfully run the prerequisite checks, installation, and post-installation steps on your cluster via the client machine.
Tool |
Description |
Download |
Required.
uipathctl is a UiPath® command-line tool that allows you to run commands against Automation Suite Kubernetes.
You can use
uipathctl to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI.
For more information, including a complete list of uipathctl operations, see the uipathctl Reference Guide.
| Required. Needed to perform prerequisite checks and installation steps. | |
| Optional. Ensure that kubectl matches the version of your cluster
as-cmk.tar.gz contains the container images and deployment manifests of UiPath® shared capabilities and UiPath® products.
| Download as-cmk.tar.gz |
mirror-registry.sh is required to configure an external Docker registry.
| Download mirror-registry.sh |
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations.
| Download hydrate-registry.sh |
as-images.txt contains the name and version of the container images that you must pull and upload into the external Docker registry.
| Download as-images.txt |
as-helm-charts.txt contain the details for the UiPath® application helm chart that you must pull and upload to an external Docker registry hosted
on your environment.
| Download as-helm-charts.txt |
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands.
| Download uipathtools |
This page provides a list of download links for all the artifacts you may need to install or configure Automation Suite. Make sure to select the version of the artifacts you target.
We have identified an issue with Integration Service on Automation Suite 2024.10.0 and 2024.10.1, which can cause increased infrastructure load, if misconfigured. As a result, we have removed Integration Service from the mentioned versions. Integration Service will be available again in Automation Suite 2024.10.2.
To re-enable Integration Service on Automation Suite versions 2024.10.0 and 2024.10.1, you must apply the corresponding patch:
Without these patches, Integration Service will remain unavailable in the mentioned Automation Suite versions.
uipathctl
commands against Automation Suite. You can use uipathctl
to check
uipathctl
is only compatible with the x86 architecture.
You cannot run uipathctl
on machines based on the ARM architecture,
such as Macs with Apple Silicon (M series) CPUs.
2024.10.4
uipathctl
for Automation Suite 2024.10.4, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gz
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gz
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gz - MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-darwin-amd64.tar.gz
2024.10.3
uipathctl
for Automation Suite 2024.10.3, run one of the following commands, depending on your OS:
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gz
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gz
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-darwin-amd64.tar.gz
2024.10.2
uipathctl
for Automation Suite 2024.10.2, run one of the following commands, depending on your OS:
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gz
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gz
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-darwin-amd64.tar.gz
2024.10.1
uipathctl
for Automation Suite 2024.10.1, run one of the
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gz
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gz
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-darwin-amd64.tar.gz
2024.10.0
uipathctl
for Automation Suite 2024.10.0, run one of the
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gz
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gz
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-darwin-amd64.tar.gz
2024.10.4
versions.json
for Automation Suite 2024.10.4, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.4/versions.json
2024.10.3
versions.json
for Automation Suite 2024.10.3, run the
following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3/versions.json
2024.10.2
versions.json
for Automation Suite 2024.10.2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2/versions.json
2024.10.1
versions.json
for Automation Suite 2024.10.1, run the
following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.1/versions.json
2024.10.0
versions.json
for Automation Suite 2024.10.0, run the
following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.0/versions.json
kubectl
matches the version of your cluster.
kubectl
, see Kubernetes documentation.
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
2024.10.4
Linux
To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command:
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zip -
Windows
To download UiPath.OrganizationMigrationApp on a Windows machine, access this link.
2024.10.3
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zip -
Windows
2024.10.2
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zip -
Windows
2024.10.1
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zip -
Windows
2024.10.0
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zip
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zip -
Windows
as-cmk.tar.gz
contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product.
as-cmk.tar.gz
. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly
from the container registry hosted in UiPath® servers.
as-cmk.tar.gz
is required during installation and upgrade.
2024.10.4
For the checksum file, access this link.
Linux:
To downloadas-cmk.tar.gz
on a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.4/as-cmk-2024.10.4.tar.gz
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.4/as-cmk-2024.10.4.tar.gz -
Windows:
2024.10.3
Linux:
on a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.3/as-cmk-2024.10.3.tar.gz
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.3/as-cmk-2024.10.3.tar.gz -
Windows:
2024.10.2
Linux:
on a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.2/as-cmk-2024.10.2.tar.gz
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.2/as-cmk-2024.10.2.tar.gz -
Windows:
2024.10.1
Linux:
on a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-cmk-2024.10.1.tar.gz
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-cmk-2024.10.1.tar.gz -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gz
Linux:
on a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gz
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gz -
Windows:
mirror-registry.sh
2024.10.4
Linux:
To downloadmirror-registry.sh
on a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.sh -
Windows:
2024.10.3
Linux:
on a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.sh -
Windows:
2024.10.2
Linux:
on a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.sh -
Windows:
2024.10.1
Linux:
on a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.sh -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh
Linux:
on a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh -
Windows:
hydrate-registry.sh
is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
2024.10.4
Linux:
To downloadhydrate-registry.sh
on a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.sh -
Windows:
2024.10.3
Linux:
on a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.sh -
Windows:
2024.10.2
Linux:
on a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.sh -
Windows:
2024.10.1
Linux:
on a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.sh -
Windows:
2024.10.0
Linux:
on a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.sh
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.sh -
Windows:
as-images.txt
contains the name and version of the container images that must be
pulled and uploaded into the external Docker registry.
2024.10.4
Linux
To downloadair-images.txt
on a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.4/air-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.4/air-images.txt -
Windows:
on a Windows machine, access this link and rename the file toas-images.txt
2024.10.3
Linux
on a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3/air-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3/air-images.txt - Windows:
To download
air-images.txt
2024.10.2
Linux
on a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2/air-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2/air-images.txt - Windows:
To download
air-images.txt
2024.10.1
Linux
on a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.1/air-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.1/air-images.txt - Windows:
To download
air-images.txt
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/air-images.txt
Linux
on a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.0/air-images.txt
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.0/air-images.txt - Windows:
To download
air-images.txt
as-helm-charts.txt
that must be pulled and uploaded to an external Docker registry hosted on your
environment.
2024.10.4
Linux:
To downloadembedded-helm-charts.txt
on a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txt -
Windows:
on a Windows machine, access this link and rename the file toas-helm-charts.txt
2024.10.3
Linux:
on a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txt -
Windows:
2024.10.2
Linux:
on a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txt -
Windows:
2024.10.1
Linux:
on a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txt -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt
Linux:
on a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt -
Windows:
uipathtools
capabilities specific to health commands. The tool is backward compatible and works with
any supported Automation Suite version. We recommend using uipathtools
as the first step if you face any issue.
2024.10.4
uipathtools
- Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gz - Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gz - MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-darwin-amd64.tar.gz
2024.10.3
uipathtools
your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-darwin-amd64.tar.gz
2024.10.2
uipathtools
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-darwin-amd64.tar.gz
2024.10.1
uipathtools
your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-darwin-amd64.tar.gz
2024.10.0
uipathtools
your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gz
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gz
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-darwin-amd64.tar.gz
- uipathctl
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- versions.json
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- kubectl
- UiPath.OrganizationMigrationApp
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-cmk.tar.gz
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- mirror-registry.sh
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- hydrate-registry.sh
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-images.txt
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-helm-charts.txt
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- uipathtools
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
