- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
Last updated Oct 3, 2025
If you encounter general issues while configuring or using Automation Suite, refer to the following:
When attempting to run a scheduled backup in Automation Suite on EKS/AKS, Velero may return the following error:
Phase: FailedValidation
Validation errors: an existing backup storage location was not specified at backup creation time and the server default default does not exist.
Error: BackupStorageLocation.velero.io "default" not found
This occurs due to the
default-bs1
not being marked as default in the Velero configuration.
To address the issue, take the following steps:
Accessing an FQDN may return the following error:RBAC: access denied
RBAC: access denied
This issue occurs because the FQDN and its relevant URL access are routed via Istio. Istio relies on a WASM plugin to route the request to the appropriate destination pod.
If the WASM plugin image is missing in the registry, internal or external, Istio blocks the URL access and returns a
RBAC: access denied
error.
Solution
To address this issue, you must ensure that the registry is hydrated and the WASM plugin image exists in registry.
To check the WASM plugin image, run teh folowing command:
kubectl get wasmplugin -A -o yaml | grep url
url: oci://testing.azurecr.io/istio-wasm-plugin:2024.10.3
. You must check if this image is present in your registry or not.
