- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Rotate exchanges the current Token Signing certificate data with the future one.
The command defaults to the current context in the
kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config token-signing-certificates rotate [flags]uipathctl config token-signing-certificates rotate [flags]# Rotate the token signing certificates from the cluster
# Rotate the token signing certificates from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates rotate --kubeconfig cluster.kubeconfig# Rotate the token signing certificates from the cluster
uipathctl config token-signing-certificates rotate --kubeconfig cluster.kubeconfig-h, --help help for rotate
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath") -h, --help help for rotate
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath")--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 5h0m0s)
--versions string optional path to versions file --context string name of the kubeconfig context to use
