- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Remove the existing Alertmanager receiver from the Alertmanager config.
uipathctl config alerts remove-email [flags]
# Remove existing receiver from alertmanager config
uipathctl config alerts remove-email --name test
-h, --help help for remove-email
--name string Name of the email configuration
