- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
The input and version files are used to configure the migration process.
uipathctl cluster migration run [PATH] [flags]uipathctl cluster migration run [PATH] [flags]# Migrate from source cluster to target cluster, using input.json/cluster_config.json as the target cluster configuration
uipathctl cluster migration run input.json/cluster_config.json --versions versions.json --target-kubeconfig <path> --target-kubecontext <context> # Migrate from source cluster to target cluster, using input.json/cluster_config.json as the target cluster configuration
-h, --help help for run
--skip-outbound-data skip outbound data migration
--skip-pre-reqs skip prerequisite checks for data migration
--target-context string name of kubeconfig context to use for target cluster
--target-kubeconfig string target cluster kubectl configuration file
--versions string path to versions file -h, --help help for run
--versions string path to versions file--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
