2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
Checksum offloading on a network card may cause issues in some setups, including on VMware instances and in Cilium. If you encounter such issues, take the following steps:
- Disable TX checksum offloading by running the
following commands:
For server machines:
cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-server.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksumcat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-server.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksum -
For agent machines:
cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-agent.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksumcat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-agent.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksum
- Restart the affected instance by taking the steps described in Starting and shutting down a node.
