2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
During backup, Longhorn volumes are backed up by taking the volume snapshot and sending it to a remote location. If snapshot creation issues affect the Longhorn volume, with the snapshot count for the volume being higher than 248, the backup will not succeed.
You can verify if the backup failed due to the
TooManySnapshots error in the following ways:
By checking the Velero logs:
kubectl logs -n velero -l app.kubernetes.io/name=velero -c velero |grep "Waiting for volumesnapshotcontents"kubectl logs -n velero -l app.kubernetes.io/name=velero -c velero |grep "Waiting for volumesnapshotcontents"Sample output:
time="2023-12-15T08:15:59Z" level=info msg="Waiting for volumesnapshotcontents snapcontent-f073b88e-bd01-40a8-a645-ec929e276cef to have snapshot handle. Retrying in 5s" backup=velero/daily-2 cmd=/plugins/velero-plugin-for-csi logSource="/go/src/velero-plugin-for-csi/internal/util/util.go:182" pluginName=velero-plugin-for-csi time="2023-12-15T08:15:59Z" level=info msg="Waiting for volumesnapshotcontents snapcontent-f073b88e-bd01-40a8-a645-ec929e276cef to have snapshot handle. Retrying in 5s" backup=velero/daily-2 cmd=/plugins/velero-plugin-for-csi logSource="/go/src/velero-plugin-for-csi/internal/util/util.go:182" pluginName=velero-plugin-for-csitime="2023-12-15T08:15:59Z" level=info msg="Waiting for volumesnapshotcontents snapcontent-f073b88e-bd01-40a8-a645-ec929e276cef to have snapshot handle. Retrying in 5s" backup=velero/daily-2 cmd=/plugins/velero-plugin-for-csi logSource="/go/src/velero-plugin-for-csi/internal/util/util.go:182" pluginName=velero-plugin-for-csi time="2023-12-15T08:15:59Z" level=info msg="Waiting for volumesnapshotcontents snapcontent-f073b88e-bd01-40a8-a645-ec929e276cef to have snapshot handle. Retrying in 5s" backup=velero/daily-2 cmd=/plugins/velero-plugin-for-csi logSource="/go/src/velero-plugin-for-csi/internal/util/util.go:182" pluginName=velero-plugin-for-csi -
By checking the Longhorn pod logs:
kubectl logs -n longhorn-system -l app=csi-snapshotter --tail=-1 |grep "too many snapshots created"kubectl logs -n longhorn-system -l app=csi-snapshotter --tail=-1 |grep "too many snapshots created"Sample output:
I1215 08:39:41.707351 1 snapshot_controller.go:291] createSnapshotWrapper: CreateSnapshot for content snapcontent-f073b88e-bd01-40a8-a645-ec929e276cef returned error: rpc error: code = Internal desc = Bad response statusCode [500]. Status [500 Internal Server Error]. Body: [code=Server Error, detail=, message=failed to create snapshot: proxyServer=10.42.7.56:8501 destination=10.42.7.56:10004: failed to snapshot volume: rpc error: code = Unknown desc = failed to create snapshot snapshot-f073b88e-bd01-40a8-a645-ec929e276cef for volume 10.42.7.56:10004: rpc error: code = Unknown desc = too many snapshots created] from [http://longhorn-backend:9500/v1/volumes/pvc-7d89efa4-3d60-4837-a632-f190cd3cd9ed?action=snapshotCreate]I1215 08:39:41.707351 1 snapshot_controller.go:291] createSnapshotWrapper: CreateSnapshot for content snapcontent-f073b88e-bd01-40a8-a645-ec929e276cef returned error: rpc error: code = Internal desc = Bad response statusCode [500]. Status [500 Internal Server Error]. Body: [code=Server Error, detail=, message=failed to create snapshot: proxyServer=10.42.7.56:8501 destination=10.42.7.56:10004: failed to snapshot volume: rpc error: code = Unknown desc = failed to create snapshot snapshot-f073b88e-bd01-40a8-a645-ec929e276cef for volume 10.42.7.56:10004: rpc error: code = Unknown desc = too many snapshots created] from [http://longhorn-backend:9500/v1/volumes/pvc-7d89efa4-3d60-4837-a632-f190cd3cd9ed?action=snapshotCreate]
If you encounter the
TooManySnapshots error, you must clean up the snapshots for all the volumes by running the following script. For details on how to automate
this operation, see How to automatically clean up Longhorn snapshots.
#!/bin/bash
set -e
# longhorn backend URL
url=
# By default, snapshot older than 10 days will be deleted
days=10
function display_usage() {
echo "usage: $(basename "$0") [-h] -u longhorn-url -d days"
echo " -u Longhorn URL"
echo " -d Number of days(should be >0). By default, script will delete snapshot older than 10 days."
echo " -h Print help"
while getopts 'hd:u:' flag "$@"; do
case "${flag}" in
u)
url=${OPTARG}
d)
days=${OPTARG}
[ "$days" ] && [ -z "${days//[0-9]}" ] || { echo "Invalid number of days=$days"; exit 1; }
h)
display_usage
exit 0
echo "Invalid option: ${OPTARG} requires an argument."
exit 1
echo "Unexpected option ${flag}"
exit 1
esac
done
[[ -z "$url" ]] && echo "Missing longhorn URL" && exit 1
# check if URL is valid
curl -s --connect-timeout 30 ${url}/v1 >> /dev/null || { echo "Unable to connect to longhorn backend"; exit 1; }
echo "Deleting snapshots older than $days days"
# Fetch list of longhorn volumes
vols=$( (curl -s -X GET ${url}/v1/volumes |jq -r '.data[].name') )
#delete given snapshot for given volume
function delete_snapshot() {
local vol=$1
local snap=$2
[[ -z "$vol" || -z "$snap" ]] && echo "Error: delete_snapshot: Empty argument" && return 1
curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotDelete -d '{"name": "'$snap'"}'
echo "Snapshot=$snap deleted for volume=$vol"
#perform cleanup for given volume
function cleanup_volume() {
local vol=$1
local deleted_snap=0
[[ -z "$vol" ]] && echo "Error: cleanup_volume: Empty argument" && return 1
# fetch list of snapshot
snaps=$( (curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotList | jq -r '.data[] | select(.usercreated==true) | .name' ) )
for i in ${snaps[@]}; do
if [[ $i == "volume-head" ]]; then
continue
fi
# calculate date difference for snapshot
snapTime=$(curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotGet -d '{"name":"'$i'"}' |jq -r '.created')
currentTime=$(date "+%s")
timeDiff=$(($currentTime - ($(date -d $snapTime "+%s")) / 86400))
if [[ $timeDiff -lt $days ]]; then
echo "Ignoring snapshot $i, since it is older than $timeDiff days"
continue
fi
#trigger deletion for snapshot
delete_snapshot $vol $i
deleted_snap=$((deleted_snap+1))
done
if [[ "$deleted_snap" -gt 0 ]]; then
#trigger purge for volume
curl -s -X POST ${url}/v1/volumes/${vol}?action=snapshotPurge >> /dev/null
fi
for i in ${vols[@]}; do
cleanup_volume $i
done#!/bin/bash
set -e
url=
days=10
case "${flag}" in
u)
url=${OPTARG}
d)
days=${OPTARG}
h)
display_usage
exit 0
exit 1
exit 1
esac
done
local vol=$1
local snap=$2
local vol=$1
continue
fi
continue
fi
done
fi
cleanup_volume $i
doneWhen executing the aforementioned script, you must pass the following arguments:
-u- The Longhorn backend URL. To get the Longhorn backend URL, run the following command:kubectl get svc -n longhorn-system longhorn-backend -o json | jq -r '.spec | (.clusterIP|tostring) + ":" + (.ports[0].port|tostring)' to fetch URLkubectl get svc -n longhorn-system longhorn-backend -o json | jq -r '.spec | (.clusterIP|tostring) + ":" + (.ports[0].port|tostring)' to fetch URL -
-d- The number of days before the snapshots are deleted.
Note:
To get a list of volumes affected by the
TooManySnapshots error, run the following command:
kubectl get volumes -n longhorn-system -o json | jq -r '.items[] | select(([ .status.conditions[] | select(.type == "toomanysnapshots" and .status == "True") ] | length ) == 1 ) | .metadata.name'kubectl get volumes -n longhorn-system -o json | jq -r '.items[] | select(([ .status.conditions[] | select(.type == "toomanysnapshots" and .status == "True") ] | length ) == 1 ) | .metadata.name'
