- Overview
- Requirements
- Cluster administration- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade- Migration options
- B) Single tenant migration
- Troubleshooting- How to Troubleshoot Services During Installation
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
The previous step is Step 3: Configuring Azure SQL.
For production deployments, DNS configuration is required. Follow the steps in Configuring the DNS to configure DNS using the provider specific to your environment.
For test or evaluation purposes, Creating a Private DNS zone in Azure can be used as a workaround. See the following section for detailed steps.
This is a workaround for testing purposes. For production, please follow the DNS configuration guide specific to your environment.
Make sure to configure the host entries in the client machine after the DNS zone is created. This is a requirement for any type of deployment.
Creating a private DNS zone
Adding a record set for all subdomains
Adding a record set for the root domain
Adding a virtual network link to the private DNS zone
Configuring a client machine to access the cluster
Once you configure the DNS, you need to add the host entries to the client machines.
This is mandatory to perform for all deployments, both evaluation/test and production.
/etc/hosts host entry is only needed in the client machines, not the cluster node.
                     Windows
MacOS or Linux
- For production deployments: Configuring the DNS
- For test or evaluation deployments: Creating a private DNS zone
- Creating a private DNS zone
- Adding a record set for all subdomains
- Adding a record set for the root domain
- Adding a virtual network link to the private DNS zone
- Configuring a client machine to access the cluster
