2022.4
- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Get All Groups
- Get Specific Group
- Delete Specific Group
- Create a New Local Group
- Update Group
Automation Suite API guide
Last updated Feb 24, 2025
linkDeletes the specified group in an organization, based on the organization and group ID.
API Endpoint
linkDELETE
https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}
Scopes
linkRequires the following scopes:
- PM.Group
- PM.Group.Write
Request Headers
link--header 'Authorization: Bearer {access_token}'\
Note: To obtain the
{access_token}
, make sure to authenticate through one of the methods described here.
Path Parameters
link
Path param |
Data type |
Description |
(required) |
String |
The ID of the organization you want to delete the group from. |
(required) |
String |
The ID of the group you want to delete. |
Example Request
linkLet's say you gathered all the information needed to build the API call.
- Your
{baseURL}
is:https://{yourDomain}/{organizationName}/{tenantName}/
Your
{access_token}
is:1234
(for length considerations). - The
{partitionGlobalId}
is:magic-7
- The
{groupId}
is:2512
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/Group/magic-7/2512' \
