- Getting started
- Authentication
- Authentication methods
- External Applications (OAuth)
- ROPC Authentication
- Scopes and permissions
- Platform Management APIs
Automation Suite API guide
As a developer working on the integration of UiPath products with external applications, you are responsible for tasks such as managing scope changes, managing access tokens and refresh tokens and maintaining the integration between the external app and UiPath resources. The following guide walks you through these operations.
OAuth offers a selection of libraries that you can leverage to simplify authentication, authorization, delegation and securing API calls. You can access these resources directly from the official OAuth website.
As a developer, once the organization admin has registered your external application in UiPath, you will need to obtain the registration details to authenticate your external app with UiPath resources.
The App Type and the App ID. If you are working with a confidential application, you will also need the App Secret. These are used to authenticate your app with UiPath's Identity Server, the authorization server for accessing UiPath resources, which supports the OAuth 2.0 framework.
Additionally, you need to know the external app scopes, which defines what resources your external app can access in UiPath. This includes both the resource specification (like Assets, Processes, etc.) and the permission level (read, write, edit, etc.).
After the external application is registered, you must implement the appropriate authorization mechanism for the external application, with the appropriate grant type, so that the external application can retrieve an access token.
During this process, request an access token by providing the scope of the external app and the credentials of the registered app - the App ID (and App Secret in the case of confidential applications) - to Identity Server. If the credentials are valid, Identity Server responds by issuing an authorization code, which will be used to generate the access token.
Which authorization grant type to use
Application Type |
Scope |
Required Grant Type |
confidential |
application |
Client credentials |
confidential |
user |
Authorization code |
confidential |
application & user |
Client credentials & Authorization code |
non-confidential |
user |
Authorization code with PKCE |
When the scope name is the same under both user and application scope, as in the case of Orchestrator, the grant type you use determines if the resource is called under user scope or under application scope.
Declaring scopes
The scope defined by the administrator for an application determines the maximum level of access that the application can attain. As a developer, if you request access beyond this predefined scope, your request fails. Therefore, it is important to ensure your requests are within the scope defined by the admin.
At the admin level, application's permissions can be:
Organization-scoped permissions: By default, when an external application is registered, it has organization-wide access to the resources according to the scopes set.
Fine-grained permissions: For more granular permission settings, the organization admin can assign a role at the tenant or folder level within Orchestrator to the external app, though this is only applicable for confidential applications.
At the developer level, declaring scopes is done as follows:
Organization-scoped permissions: When you declare an explicitly specified scope like
OR.Machines.Viewin the token request, it implies that the application is requesting an organization-wide access permission. -
Fine-grained permissions: To provide your application with fine-grained access, you must declare
OR.Defaultin the token request.OR.Defaultacts like a wildcard scope, providing your application with fine-grained access that depends on its assigned role in specific tenants or folders.
OR.Machines.View and OR.Default. This combined declaration allows your external application to operate both at an organization-wide level and specific Orchestrator
tenants or folders.
Check the endpoint in the API documentation of the resource to get the scope values you need. For example:
Confidential apps with app scopes (client credentials flow)
With this grant type, the flow is as follows:
The external application requests an access token by sending a POST request that includes the
client_idandclient_secretto the Identity Server token endpoint::https://{yourDomain}/{organizationName}/identity_/connect/tokengrant_type=client_credentials&client_id={app_id}&client_secret={app_secret}&scope={scopes}grant_type=client_credentials&client_id={app_id}&client_secret={app_secret}&scope={scopes}Field
client_idSpecifies the unique identifier assigned to the application during its registration.
Must contain the App ID (provided by the administrator).
client_secretSpecifies confidential piece of information, like a password, that is provided to confidential applications upon their registration. This field is used along with theclient_idto authenticate the application when it issues requests to the Identity Server.Must contain the App Secret (provided by the administrator).
scopeSpecifies the scopes requested by the application, delimited by a space; for example:OR.Machines.View OR.Default.-
Use
OR.Defaultto grant controlled, customized access within specific tenants or folders. The actual permissions the application gets are determined based on where the application is assigned within tenants or folders by the administrator. -
Use explicit scopes like
OR.Machines.Viewto grant broad, organization-wide access to certain resources.
The external application receives a response containing the access token:The application can use the access token to access user resources until the token expires (one hour).
{ "access_token":"{access_token}", "expires_in":3600, "token_type":"Bearer", "scope":"{scopes}" }{ "access_token":"{access_token}", "expires_in":3600, "token_type":"Bearer", "scope":"{scopes}" }
Confidential apps with user scopes (authorization code flow)
For a detailed understanding of the OAuth flow utilizing authorization codes, please refer to the RFC 6749 document.
application/x-www-form-urlencodedThe application can use the access token to access user resources until the token expires (one hour).
Non-confidential apps with user scopes (authorization code with PKCE flow)
For a non-confidential application with user scopes, you perform the authorization code with PKCE flow. For a detailed understanding of the OAuth flow utilizing authorization code with PKCE, please refer to the RFC 7636 document.
The external application sends an authorize request to get the authorization code to the
https://{yourDomain}/{organizationName}/identity_/connect/authorize?endpoint:response_type=code&client_id={app_id}&scope={scopes}&redirect_uri={redirect_url}&code_challenge={cryptographically-random string from code_verifier}&code_challenge_method=S256response_type=code&client_id={app_id}&scope={scopes}&redirect_uri={redirect_url}&code_challenge={cryptographically-random string from code_verifier}&code_challenge_method=S256Option
Must contain the App ID (as provided by the administrator).
scopeSpecifies the scopes requested by the application, delimited by a space; for example:OR.Machines.View.redirect_uriSpecifies the URL where UiPath Identity Server redirects the authorize request after the authorization code is granted.
code_challenge_methodSpecifies the method used to encode thecode_verifierfor thecode_challenge. The value for this field must be S256, meaning thecode_verifiershould be hashed using SHA256 and base64url-encoded to create thecode_challenge.code_challengeA cryptographically-random string derived from thecode_verifier, used to connect the authorization request to the token request.You must use a code verifier algorithm to generate the code challenge. You can also create your own, as long as it complies with the rfc7636 standard.
In the POST token request to
https://{identity_baseURL}/connect/token, you need to includecode_verifier(the original string used to generatecode_challenge) in the request body.The response includes an access token which the application can use to access user resources until the token expires (one hour).grant_type=authorization_code&code={authorization_code}&redirect_uri={redirect_url}&client_id={app_id}&code_verifier={code_verifier}grant_type=authorization_code&code={authorization_code}&redirect_uri={redirect_url}&client_id={app_id}&code_verifier={code_verifier}
After the application has an access token, it can use the token to access allowed resources, limited to the selected scopes, until the token expires (one hour).
odata/Machines API that uses an access token in the Authorization header, where the access token contains OR.Machines scope in the scope claim.
curl -X GET "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Machines"
-H "Authorization: Bearer {access_token}" -H "accept: application/json"curl -X GET "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Machines"
-H "Authorization: Bearer {access_token}" -H "accept: application/json"Access tokens expire in one hour. The external application can get a new access token without user interaction by exchanging a refresh token for it. Both confidential and non-confidential external applications can request a refresh token. However, the client credentials flow does not support refresh tokens. In the client credentials flow, access tokens are granted directly without refresh tokens. When clients need a new token, they must reauthenticate using their credentials.
Refresh tokens are also valid for only one use and they expire after 60 days.
offline_access in the scope parameter of the authorize request so that the authorization code can be used in a token request to get a refresh token.
Getting a refresh token
POST request with the authorization code to the token endpoint
https://{yourDomain}/{organizationName}/identity_/connect/token.
application/x-www-form-urlencoded.
The request returns a new access token and a refresh token:
"access_token": "{access_token}",
"expires_in": 3600,
"token_type": "Bearer",
"refresh_token": "{refresh_token}",
"scope": "OR.Machines OR.Robots offline_access"
"expires_in": 3600,
}Getting a new refresh token and a new access token
POST request to the token endpoint https://{yourDomain}/{organizationName}/identity_/connect/token using the refresh_token grant type.
"grant_type": "refresh_token",
"client_id": "{app_id}",
"client_secret": "{app_secret}",
"refresh_token": "{existing_refresh_token}"
}client_secret parameter from the request body.
The response returns a new access token and a new refresh token.
The existing refresh token is no longer valid after use, so make sure you use the new refresh token you received.
application/x-www-form-urlencoded for any requests to Identity Server endpoints. If you are making requests programmatically, this is not required.
| Identity Server layer | Endpoint | Description |
| Discovery | https://{yourDomain}/{organizationName}/identity_/.well-known/openid-configuration | Use this endpoint to retrieve metadata about your Identity Server instance. |
| Authorization | https://{yourDomain}/{organizationName}/identity_/connect/authorize | Use this endpoint to request tokens or authorization codes via the browser. This process includes authentication of the end-user and optionally consent. |
| Token | https://{yourDomain}/{organizationName}/identity_/connect/token | Use this endpoint to programmatically request tokens.
Note that for this endpoint, the content type must be
- Prerequisites
- Authenticating and authorizing external apps
- Which authorization grant type to use
- Declaring scopes
- Confidential apps with app scopes (client credentials flow)
- Confidential apps with user scopes (authorization code flow)
- Non-confidential apps with user scopes (authorization code with PKCE flow)
- Using the access token
- Obtaining a refresh token
- Getting a refresh token
- Getting a new refresh token and a new access token
- UiPath® Identity Server endpoints
