- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Licensing product codes
- Allocate Licenses to an Organization
- Allocate Licenses to a Tenant
- Allocate Licenses to a Group
- Allocate Licenses to a User
Automation Suite API guide
As a host admin, you can use endpoint to allocate licenses to an organization, based on the organization ID.
PUT https://{yourDomain}/lrm/api/host/{hostAccountID}/organization/{organizationId}/license--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'{access_token}, make sure to authenticate through the ROPC method described here.
Path param |
Data type |
Description |
(required) |
String |
The ID of the host account that allocates the licenses. Warning:
Always use the default value:
feb0dd79-85b6-483b-b297-0e49a1aa5b7d |
(required) |
String |
The ID of the organization you want to allocate licenses to. |
The request body contains the array of license codes for various products and their corresponding quantity.
"productQuantities":
{ "code": "string", "quantity": 0 }
}- To see the available license codes you may use in the request body, check out License codes.
- You may allocate as many licenses as the organization has purchased.
200 OK
Returns the allocated licenses.404
The host license does not exist or the feature flag for on-premise flows is off.
409
The license allocation is not allowed because it exceeds the host license quantities.
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://tom-jones-server.com - Your
{access_token}is:1234(for length considerations). - Your
{hostAccountId}is:j0ne5 - The
{organizationId}that needs license allocation is:y-y-y-delilah - You want to allocate product licenses to the organization as follows:
- 2 Unattended Robots (the license code is
UNATT) - 1 AI Center Pro license (the license code is
AIG) - 3 Testing licenses (the license code is
TAUNATT)
The call should resemble the following example (cURL):
curl --location --request POST 'https://tom-jones-server.com/lrm/api/host/j0ne5/organization/y-y-y-delilah/license' \
--header 'Content-Type: application/json' \
--data-raw '{
{ "code": "UNATT", "quantity": 2 },
{ "code": "AIG", "quantity": 1 },
{ "code": "TAUNATT", "quantity": 3 }
}'curl --location --request POST 'https://tom-jones-server.com/lrm/api/host/j0ne5/organization/y-y-y-delilah/license' \
--data-raw '{
}'Here's the response body for a successful license allocation:
"accountId": "y-y-y-delilah",
"bundleCode": "string",
"endDate": 0,
"gracePeriod": 0,
"licenseCode": "string",
"licenseStatus": "string",
"products": [
"code": "string",
"quantity": 0,
"type": "string",
"features": [
"code": "string",
"type": "string",
"value": "string"
"templates": [
"productCode": "string",
"products": [
"code": "string",
"type": "string"
"startDate": 0,
"subscriptionCode": "string",
"subscriptionPlan": "string",
"payload": "string",
"type": "string",
"parentLicenseCode": "string"
"endDate": 0,
"gracePeriod": 0,
"products": [
"code": "string",
"quantity": 0,
"type": "string",
"features": [
"code": "string",
"type": "string",
"value": "string"
"templates": [
"products": [
"code": "string",
"type": "string"
"startDate": 0,
"type": "string",
