- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
- Exploring summarized telemetry
Configuring NLog
Adding NLog extensions
Orchestrator loads the following extensions by default, so you do not need to include them in the folder or the NLog configuration:
NLog.Targets.ElasticSearchUiPath.Orchestrator.Logs.ElasticsearchMicrosoft.ApplicationInsights.NLogTargetNLog.Extensions.AzureEventHub
Only Linux-compatible extensions can be used in this setup, so make sure that your chosen NLog extension abides by this rule.
To make the extension available for use, it must uploaded to the cluster storage. The uipathctl command line tool can do this via the uipathctl config orchestrator upload command:
./bin/uipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directory
If you use an external storage configuration at the cluster level, you must indicate this by including the --is-external-storage parameter.
Advanced NLog configuration
Creating the advanced NLog configuration
Create the
nlog.config.jsonfile containing the standard sections: extensions, targets and rules.The extensions section is an array of items that specify the extension assemblies, via
assemblyFile, and the path of the assembly.If custom NLog plugins were loaded (as described in the Adding NLog extensions section), they will be referenced in the
extensionssection. -
Configure the target and rule in the
nlog.config.jsonfile. -
Apply the
nlog.config.jsonfile using theuipathctlcommand line tool:./bin/uipathctl config orchestrator update-config --nlog-config nlog.custom.json./bin/uipathctl config orchestrator update-config --nlog-config nlog.custom.jsonImportant:This action overwrites the existing custom NLog configuration. You can check what the existing configuration is by using this command: assignment
./bin/uipathctl config orchestrator get-config --nlog-config./bin/uipathctl config orchestrator get-config --nlog-configExample
nlog.config.jsonfile that writes logs to Azure Blob:{ "NLog": { "extensions": [ { "assemblyFile": "NLog.Extensions.AzureBlobStorage.dll" } ], "targets": { "azureBlob": { "type": "AzureBlobStorage", "connectionString": "DefaultEndpointsProtocol=https;AccountName=test;AccountKey=key;EndpointSuffix=core.windows.net", "container": "orchestratorlogs", "blobName": "${date:format=yyyy-MM-dd hh.mm}", "layout": { "type": "JsonLayout", "includeAllProperties": true, "Attributes": [ {"name": "ts","layout": "${longdate}"}, {"name": "level","layout": "${level:upperCase=true}"}, {"name": "logger","layout": "${logger}"}, {"name": "message","layout": "${message}"}, {"name": "exception","layout": "${onexception:${ui-pretty-exception}}"} ] } } }, "rules": { "70_Final": { "writeTo": "stdout,azureBlob" } } } }{ "NLog": { "extensions": [ { "assemblyFile": "NLog.Extensions.AzureBlobStorage.dll" } ], "targets": { "azureBlob": { "type": "AzureBlobStorage", "connectionString": "DefaultEndpointsProtocol=https;AccountName=test;AccountKey=key;EndpointSuffix=core.windows.net", "container": "orchestratorlogs", "blobName": "${date:format=yyyy-MM-dd hh.mm}", "layout": { "type": "JsonLayout", "includeAllProperties": true, "Attributes": [ {"name": "ts","layout": "${longdate}"}, {"name": "level","layout": "${level:upperCase=true}"}, {"name": "logger","layout": "${logger}"}, {"name": "message","layout": "${message}"}, {"name": "exception","layout": "${onexception:${ui-pretty-exception}}"} ] } } }, "rules": { "70_Final": { "writeTo": "stdout,azureBlob" } } } }Example
nlog.config.jsonfile that writes robot logs to Splunk:{ "Nlog": { "extensions": [ { "assemblyFile": "NLog.Targets.Splunk.dll" }, { "assembly": "UiPath.Orchestrator.Logs.DatabaseBulk.NLogTarget" } ], "targets": { "Splunk": { "type": "BufferingWrapper", "flushTimeout": 5000, "target": { "type": "SplunkHttpEventCollector", "serverUrl": "http://splunk.example.com", "token": "splunk-token", "channel": "", "source": "${logger}", "sourceType": "_json", "index": "uipath", "retriesOnError": "0", "batchSizeBytes": "0", "batchSizeCount": "0", "includeEventProperties": "true", "includePositionalParameters": "true", "includeMdlc": "true", "maxConnectionsPerServer": "10", "ignoreSslErrors": "false", "useProxy": "false", "proxyUrl": "", "proxyUser": "", "proxyPassword": "" } } }, "rules": { "20_Robot_Primary": { "writeTo": "Splunk,database,insightsRobotLogs" } } } }{ "Nlog": { "extensions": [ { "assemblyFile": "NLog.Targets.Splunk.dll" }, { "assembly": "UiPath.Orchestrator.Logs.DatabaseBulk.NLogTarget" } ], "targets": { "Splunk": { "type": "BufferingWrapper", "flushTimeout": 5000, "target": { "type": "SplunkHttpEventCollector", "serverUrl": "http://splunk.example.com", "token": "splunk-token", "channel": "", "source": "${logger}", "sourceType": "_json", "index": "uipath", "retriesOnError": "0", "batchSizeBytes": "0", "batchSizeCount": "0", "includeEventProperties": "true", "includePositionalParameters": "true", "includeMdlc": "true", "maxConnectionsPerServer": "10", "ignoreSslErrors": "false", "useProxy": "false", "proxyUrl": "", "proxyUser": "", "proxyPassword": "" } } }, "rules": { "20_Robot_Primary": { "writeTo": "Splunk,database,insightsRobotLogs" } } } }
Updating the advanced NLog configuration
The uipathctl commands needed for updating the NLog configuration are:
./bin/uipathctl config orchestrator get-config --nlog-config- This exports the current configuration in a key-value pair json file, ready for editing. You can read more about it ../bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json- This updates the configuration with your changes. You can read more about it .
Export the current custom NLog configuration to a json file using this command:
./bin/uipathctl config orchestrator get-config --nlog-config > nlog.config.json./bin/uipathctl config orchestrator get-config --nlog-config > nlog.config.json -
Edit the exported
nlog.config.jsonfile as needed. You can add, remove, or change any of its settings.Note:You must export the file again every time you need to make a change, since the update overwrites all NLog settings.
Update the NLog configuration using this command:
./bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json orchestrator config updated./bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json orchestrator config updated
