Last updated Nov 13, 2025
Management alerts
alertmanager.rules
AlertmanagerConfigInconsistent
This alert fires when Alertmanager instances within the same cluster have different configurations. This could indicate a problem with the configuration rollout which is not consistent across all the instances of Alertmanager.
To fix the issue, take the following steps:
  1. Run a diff tool between all alertmanager.yml that are deployed to identify the problem.
  2. Delete the incorrect secret and deploy the correct one.
If the issue persists, contact UiPath® Support.
AlertmanagerFailedReload
AlertManager has failed to load or reload configuration. Please check any custom AlertManager configurations for input errors and otherwise contact UiPath® Support and provide the support bundle. For details, see Using the Automation Suite support bundle.
AlertmanagerMembersInconsistent
These are internal Alertmanager errors for HA clusters with multiple AlertManager replicas. Alerts may appear and disappear intermittently. Temporarily scaling down, then scaling up Alertmanager replicas may fix the issue.
  1. Scale to zero. Note that it takes a moment for the pods to shut down:
    statefulset.apps/alertmanager-monitoring-kube-prometheus-alertmanager scaledstatefulset.apps/alertmanager-monitoring-kube-prometheus-alertmanager scaled
  2. Scale back to two:
    kubectl scale statefulset -n monitoring alertmanager-monitoring-kube-prometheus-alertmanager --replicas=2kubectl scale statefulset -n monitoring alertmanager-monitoring-kube-prometheus-alertmanager --replicas=2
  3. Check if the Alertmanager pods started and are in the running state:
    kubectl get po -n monitoringkubectl get po -n monitoring
general.rules
TargetDown
Prometheus is not able to collect metrics from the target in the alert, which means Grafana dashboards and further alerts based on metrics from that target are not be available. Check other alerts pertaining to that target.
Watchdog
This is an alert meant to ensure that the entire alerting pipeline is functional. This alert is always firing. Therefore, it should always be firing in AlertManager and against a receiver. There are integrations with various notification mechanisms that notify you when this alert is not firing. For example, the DeadMansSnitch integration in PagerDuty.
prometheus-operator
PrometheusOperatorListErrors, PrometheusOperatorWatchErrors, PrometheusOperatorSyncFailed, PrometheusOperatorReconcileErrors, PrometheusOperatorNodeLookupErrors, PrometheusOperatorNotReady, PrometheusOperatorRejectedResources
Internal errors of the Prometheus operator, which controls Prometheus resources. Prometheus itself may still be healthy while these errors are present; however, this error indicates there is degraded monitoring configurability. Contact UiPath® Support.
prometheus
PrometheusBadConfig
Prometheus has failed to load or reload configuration. Please check any custom Prometheus configurations for input errors. Otherwise contact UiPath® Support.
PrometheusErrorSendingAlertsToSomeAlertmanagers, PrometheusErrorSendingAlertsToAnyAlertmanager, PrometheusNotConnectedToAlertmanagers
The connection from Prometheus to AlertManager is not healthy. Metrics may still be queryable, and Grafana dashboards may still show them, but alerts will not fire. Check any custom configuration of AlertManager for input errors and and otherwise contact UiPath® Support.
PrometheusNotificationQueueRunningFull, PrometheusTSDBReloadsFailing, PrometheusTSDBCompactionsFailing, PrometheusNotIngestingSamples, PrometheusDuplicateTimestamps, PrometheusOutOfOrderTimestamps, PrometheusRemoteStorageFailures, PrometheusRemoteWriteBehind, PrometheusRemoteWriteDesiredShards
Internal Prometheus errors indicating metrics may not be collected as expected. Please contact UiPath® Support.
PrometheusRuleFailures
This may happen if there are malformed alerts based on non-existent metrics or incorrect PromQL syntax. Contact UiPath® Support if no custom alerts have been added.
PrometheusMissingRuleEvaluations
Prometheus is not able to evaluate whether alerts should be firing. This may happen if there are too many alerts. Please remove expensive custom alert evaluations and/or see documentation on increasing CPU limit for Prometheus. Contact UiPath® Support if no custom alerts have been added.
PrometheusTargetLimitHit
There are too many targets for Prometheus to collect from. If extra ServiceMonitors have been added (see Monitoring console), you can remove them.
uipath.prometheus.resource.provisioning.alerts
PrometheusMemoryUsage, PrometheusStorageUsage
These alerts warn when the cluster is approaching the configured limits for memory and storage. This is likely to happen on clusters with a recent substantial increase in usage (usually from Robots rather than users), or when nodes are added to the cluster without adjusting Prometheus resources. This is due to an increase in the amount of metrics being collected. This could also be due to a large number of alerts that are being fired, it is important to check why the large amount of alerts are being fired.
If this issue persists, contact UiPath® Support with the generated support bundle.
uipath.availability.alerts
UiPathAvailabilityHighTrafficUserFacing
The number of http 500 responses from UiPath® services exceeds a given threshold.
Traffic level
Number of requests in 20 minutes
Error threshold (for http 500s)
High
>100,000
0.1%
Medium
Between 10,000 and 100,000
1%
Low
< 10,000
5%
Errors in user-facing services would likely result in degraded functionality that is directly observable in the Automation Suite UI, while errors in backend services would have less obvious consequences.
The alert indicates which service is experiencing a high error rate. To understand what cascading issues there may be from other services that the reporting service depends on, you can use the Istio Workload dashboard, which shows errors between services.
Please double check any recently reconfigured Automation Suite products. Detailed logs are also available with the kubectl logs command. If the error persists, please contact UiPath® Support.
backup
NFSServerDisconnected
This alert indicates that the NFS server connection is lost.
You need to check the NFS server connection and mount path.
VolumeBackupFailed
This alert indicates that the backup failed for a PVC.
To address this issue, take the following steps:
  1. Check the status of the PVC to ensure it is Bound to a Persistent Volume (PV).
    kubectl get pvc --namespace <namespace>kubectl get pvc --namespace <namespace>
    The command lists all PVCs and their current status. The PVC should have a status of Bound to indicate it has successfully claimed a PV.
    If the status is Pending, it means the PVC is still waiting for a suitable PV, and further investigation is needed.
  2. If the PVC is not in a Bound state or if you need more detailed information, use the describe command:
    kubectl describe pvc <pvc-name> --namespace <namespace>kubectl describe pvc <pvc-name> --namespace <namespace>
    Look for information on the status, events, and any error messages. For example, an issue could be related to storage class misconfigurations or quota limitations.
  3. Check the health of the Persistent Volume (PV) that is bound to the PVC:
    kubectl get pv <pv-name>kubectl get pv <pv-name>
    The status should be Bound. If the PV is in a Released or Failed state, it may indicate issues with the underlying storage.
  4. If the PVC is used by a pod, check whether the pod has successfully mounted the volume:
    kubectl get pod <pod-name> --namespace <namespace>kubectl get pod <pod-name> --namespace <namespace>
    If the pod is in a Running state, it indicates that the PVC is mounted successfully. If the pod is in an error state (such as InitBackOff), it might indicate issues with volume mounting.
  5. If there are issues with mounting the PVC, describe the pod to check for any mounting errors:
    kubectl describe pod <pod-name> --namespace <namespace>kubectl describe pod <pod-name> --namespace <namespace>
BackupDisabled
This alert indicates that the backup is disabled.
You need to enable backup.
BackupPartiallyFailed
This alert indicates that the Velero backup has failed.
You need to contact UiPath® support.
cronjob-alerts
CronJobSuspended
The uipath-infra/istio-configure-script-cronjob cronjob is in suspended state.
To fix this issue, enable the cronjob by taking the following steps:
export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" && export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin"
kubectl -n uipath-infra patch cronjob istio-configure-script-cronjob -p '{"spec":{"suspend":false}}'
epoch=$(date +"%s")
kubectl -n uipath-infra create job istio-configure-script-cronjob-manual-$epoch --from=cronjob/istio-configure-script-cronjob
kubectl -n uipath-infra wait --for=condition=complete --timeout=300s job/istio-configure-script-cronjob-manual-$epoch
kubectl get node -o wide
#Verify if all the IP's listed by the previous command are part of output of the following command
kubectl -n istio-system get svc istio-ingressgateway -o json | jq '.spec.externalIPs'export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" && export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin"
epoch=$(date +"%s")
IdentityKerberosTgtUpdateFailed
This job updates the latest Kerberos ticket to all the UiPath® services. Failures in this job would cause SQL server authentication to fail. Please contact UiPath® Support.
