- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
Make sure to enable the following ports on your firewall for each source:
Port |
Protocol |
Source |
Purpose |
Requirements |
TCP |
Jump Server / client machine |
For SSH (installation, cluster management debugging) |
Do not open this port to the internet. Allow access to the client machine or jump server. |
TCP |
All nodes in a cluster and the load balancer |
For HTTPS (accessing Automation Suite) |
This port must have inbound and outbound connectivity from all the nodes in the cluster and the load balancer. |
TCP |
All nodes in a cluster |
etcd client port |
Do not open this port to the internet. Access between nodes must be ensured over a private IP address. |
TCP |
etcd peer port |
TCP |
For accessing Kube API using HTTPS, and required for node joining |
This port must have inbound and outbound connectivity from all the nodes in the cluster. |
UDP |
Required for Cilium. |
TCP |
All nodes in the cluster |
Used by Cilium for monitoring and handling pod crashes |
TCP |
For accessing Kube API using HTTPS, required for node joining |
This port must have inbound and outbound connectivity from all nodes in the cluster and the load balancer. |
TCP |
kubelet / metrics server |
TCP |
NodePort port for internal communication between nodes in a cluster |
The following additional ports are required in offline installations:
Port |
Protocol |
Source |
Purpose |
Requirements |
TCP |
Required for sending system email notifications |
Do not open this port to the internet. Access between nodes and the SMTP server must be ensured over a private IP address. |
TCP |
300701 |
TCP | The machine on which you plan to trigger the installation or upgrade. | For accessing the temporary registry during installation and upgrade using HTTP. | Traffic on this port must be forwarded to the Temporary Registry Pool. |
30070 on the machine on which you plan to trigger the installation or upgrade.
Exposing port 6443 outside the cluster boundary is mandatory if there is a direct connection to the Kerberos API.
Port 9345 is used by nodes to discover existing nodes and join the cluster in the multi-node deployment. To keep the high availability discovery mechanisms running, we recommend exposing it via the load balancer with health check.
Additionally, make sure you have connectivity from all nodes to the SQL server. Do not expose the SQL server on one of the Istio reserved ports, as it may lead to connection failures.
If you have a firewall set up in the network, make sure that it has these ports open and allows traffic according to the aforementioned requirements.
