- Release notes
 - Getting Started
 - Permissions
 - Starting as
 - Admin Console
 - Workspace
 - Explore
 - Share Idea or Automation
 - Dashboards
 - My Tasks
 - Notifications
 - Email Notifications
 - Resources
 - Studio Integration
 - Task Capture Integration
 - Automation Store
 - Additional Resources
Automation Hub User Guide
Last updated Sep 24, 2025
After successfully logging in, you, as a Standard User are encouraged to Share Ideas and upload Components that will boost the company’s RPA assimilation to get inspired you can check out the shared for your tenant.
Within the Workspace Overview module, you can have a detailed view over:
- Your collaborations;
 - Your components;
 - The Ideas you follow.
- view the and choose to follow the ones that drow your attention,
 - check out and download the components submitted within your tenant,
 - access the Leaderboard.
