2022.4
- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Starting as a Standard User
Automation Hub User Guide
Last updated Oct 17, 2024
After successfully logging in, you, as a Standard User are encouraged to Share Ideas and upload Components that will boost the company’s RPA assimilation to get inspired you can check out the list of Ideas shared for your tenant.
Within the Workspace module, you can have a detailed view over:
- Your ideas;
- Your collaborations;
- Your components;
- The Ideas you follow.
By accessing the Explore module you can:
- view the ideas shared by your colleagues and choose to follow the ones that drow your attention,
- check out and download the components submitted within your tenant,
- access the Leaderboard.
