Automation Hub User Guide
Last updated Jun 26, 2025
Enable Insights Connection
  1. Open Automation Hub.
  2. Go to Admin Console.
  3. Navigate to Platform Setup > Insights connection.
  4. Enable the Connection status toggle.
This action will trigger:
  • The data movement - a job will periodically extract the data from Automation Hub database (once every hour).
  • Two Dashboard tiles are made available in the UiPath Templates tab in Insights, named Automation Hub Ageing Report and Automation Hub.
Note: The first time you enable the Insights connection, it can take up to one hour to have the data populated in the Automation Hub dashboards displayed in Insights.
Disable Insights Connection
  4. Disable the Connection status toggle.
This action will stop the job extracting the data and remove the Automation Hub Templates from Insights.
In case the templates were copied, enhanced, and used in "My dashboard" & "Tenant" sections, those dashboards will remain, but will be "frozen", and will show the data available when the connection was disabled (no further updates).
If the connection will be re-enabled, the data will be refreshed.
  • Enable Insights Connection
  • Disable Insights Connection
