- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Input field definitions for the Event log app template in Process Mining on Automation Suite, including required file formats and dataset structure.
Introduction
If your data for cases and events is available in one input file, you use the Event log app template.
If you want to create a new Event log or Custom process app, you must upload a dataset that contains the data to be used in the process app.
This must be a tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names (in English) in the following table and that the file name is Event_log_raw.
Mandatory and optional Fields
Your input data file can have different fields or different field names. However, some fields are mandatory, which means that the data must be available in your input data file for a correct working the process app.
When a field is mandatory, it should not contain NULL values.
Field types
The following table describes the different field types and their default format settings.
| Field type | Format |
| boolean | true, false, 1, 0 |
| datetime | yyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional. Refer to the official Microsoft documentation if you want to change the date format. |
| double | Decimal separator: . (dot) Thousand separator: none |
| text | N/A |
| integer | Thousand separator: none |
The following table describes the input fields. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Event_log_raw
The Event_log_raw table contains information on the activities executed in the process.
| Name | Data type | Mandatory Y/N | Description |
Activity | text | Y | The name of the event. This describes the step in the process. |
Case_ID | text | Y | The unique identifier of the case the event belongs to. |
Event_end | datetime | Y | The timestamp associated with the end of executing the event. |
Case | text | N | A user-friendly name to identify the case. |
Case_status | text | N | The status of the case in the process. For example, open, closed, pending, approved, etc. |
Case_type | text | N | The categorization of the cases. |
Case_value | double | N | A monetary value related to the case. |
Automated* | boolean | N | Indicates whether the event is manually executed or automated. |
Event_detail | text | N | Information related to the event. |
Event_start | datetime | N | The timestamp associated with the start of executing the event. |
Team | text | N | The team that executed the event. |
User | text | N | The user who executed the event. |
*) Automated is part of the input data. However, if you need to derive whether an event is automated or not, you need to customize this in the data transformations to create that logic based on the required information. It is recommended to do this in the Event_log.sql file. Locate the statement that contains ...as "Automated" and replace it, for example, with a statement as displayed in the following code block.
case when Event_log_base."User" = 'A' then {{pm_utils.to_boolean('true')}} else {{pm_utils.to_boolean('false')}} end as "Automated"
Event_cost and Event_processing_time
Event_cost and Event_processing_time used to calculate Automation potential are not part of the input data. You can configure these fields in Data transformations using SQL statements. Check out Configuring fields for Automation potential for more information.
