- Release notes
- Before you begin- Installing Automation Suite
- Process Mining configuration checklist
- System requirements
- Getting started
- Integrations
- Working with process apps- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Process Mining
Last updated Sep 24, 2025
After installing and enabling Process Mining on your on-premises (Automation Suite) environment, make sure to check the list present in this guide that evaluates if Process Mining is working properly.
