Process Mining user guide
Process Mining configuration checklist
Configuration checklist for verifying that Process Mining is working correctly after installation and enablement on an Automation Suite environment.
Introduction
After installing and enabling Process Mining on your on-premises (Automation Suite) environment, make sure to check the list present in this guide that evaluates if Process Mining is working properly.
Process Mining portal
Managing access
Apps
Loading data
Customizing apps
Working with process apps
  • Introduction
  • Process Mining portal
  • Managing access
  • Apps
  • Loading data
  • Customizing apps
  • Working with process apps
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
