Process Mining user guide
Event log input fields
Input field reference for the Event log app template on Automation Suite, covering required file formats and field specifications for single-file case and event datasets.
Introduction​
If your data for cases and events is available in one input file, you use the Event log app template.
If you want to create a new Event log or Custom process app, you must upload a dataset that contains the data to be used in the process app.
This must be a tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
Important:
Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names (in English) and that the file name matches the table name.
Mandatory and optional Fields​
Your input data file can have different fields or different field names. However, some fields are mandatory, which means that the data must be available in your input data file for a correct working the process app.
Note:
When a field is mandatory, it should not contain NULL values.
Field types​
The following table describes the different field types and their default format settings.
Field typeFormat
booleantrue, false, 1, 0
datetimeyyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional. Refer to the official Microsoft documentation if you want to change the date format.
doubleDecimal separator: . (dot) Thousand separator: none
textN/A
integerThousand separator: none
The following table describes the input fields. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Event_log_raw​
The Event_log_raw table contains information on the activities executed in the process.
NameData typeMandatory Y/NDescription
ActivitytextYThe name of the event. This describes the step in the process.
Case_IDtextYThe unique identifier of the case the event belongs to.
Event_enddatetimeYThe timestamp associated with the end of executing the event.
CasetextNA user-friendly name to identify the case.
Case_statustextNThe status of the case in the process. For example, open, closed, pending, approved, etc.
Case_typetextNThe categorization of the cases.
Case_valuedoubleNA monetary value related to the case.
Automated*booleanNIndicates whether the event is manually executed or automated.
Event_detailtextNInformation related to the event.
Event_startdatetimeNThe timestamp associated with the start of executing the event.
TeamtextNThe team that executed the event.
UsertextNThe user who executed the event.
*) Automated is part of the input data. However, if you need to derive whether an event is automated or not, you need to customize this in the data transformations to create that logic based on the required information. It is recommended to do this in the Event_log.sql file. Locate the statement that contains ...as "Automated" and replace it, for example, with a statement as displayed in the following code block.
case when Event_log_base."User" = 'A' then {{pm_utils.to_boolean('true')}} else {{pm_utils.to_boolean('false')}} end as "Automated"
Event_cost and Event_processing_time​
Event_cost and Event_processing_time used to calculate Automation potential are not part of the input data. You can configure these fields in Data transformations using SQL statements. Check out Configuring fields for Automation potential for more information.
  • Introduction​
  • Mandatory and optional Fields​
  • Field types​
  • Event_log_raw​
  • Event_cost and Event_processing_time​
Connect
Stay updated
