- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Process Mining
Last updated Jul 24, 2025
2024.10.1
linkRelease date: December 18, 2024
linkData transformations
Dbt projects now run with dbt version 1.8.4. Check out the official dbt documentation to make use of the latest dbt functionalities.
With the introduction of unit tests in dbt version 1.8, the
tests:
key was renamed to data_tests:
. For existing process apps, this results in a deprecation warning that is displayed when loading data or opening Data transformations.[WARNING]: Deprecated functionality The `tests` config has been renamed to `data_tests`. Please see https://docs.getdbt.com/docs/build/data-tests#new-data_tests-syntax
for more information.
For default process apps, you can rename the occurrences of the
tests:
config to data_tests:
in the dbt_project.yml
and the sources.yml
files to fix this. For customized process apps, this can be present in other .yml
files as well.
Check out the official dbt documentation on the New data_tests:
syntax for more information.
Process cropping filter
There was an issue when using the Process cropping filter in Conformance checking that an assertion error could occur. This is now solved.
We are constantly striving to improve your UiPath® Process Mining experience. While this release brings no major changes, we included security and accessibility improvements, as well as minor bug fixes.
