Last updated Dec 4, 2025
Step 2: Updating AD integration and authentication
To configure AD integration, refer to Configuring SSO: Active Directory.
If AD integration and authentication were enabled in the standalone deployment, take the following steps in the Automation Suite cluster:
  • Make sure the domain controllers are discoverable by the Automation Suite cluster. If not, use the Kube DNS configuration;
  • Configure integrated Windows authentication and Kerberos authentication using keytab file;
  • Configure LDAP integration via the Portal under the host admin;
  • Configure Windows authentication via the Portal under the host admin;
  • Configure LDAPS for secure connection to LDAP.
    Note: The account used for the LDAP integration configuration should only have read access to all trusted domains in the current and trusted forests.
