- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
Last updated Oct 3, 2025
To start the migration operation, take the following steps:
Move the Identity organization data from standalone to Automation Suite. Details...
Restore the standalone product database. Details...
Back up the platform database in Automation Suite. Details...
Merge the organizations in Automation Suite. Details...
Update the migrated product connection strings. Details...
Migrate standalone Orchestrator. Details...
Migrate standalone Insights. Details...
Delete the default tenant. Details...
