Last updated Dec 4, 2025
Test Automation SQL connection string is ignored
When you provide an SQL connection string under the orchestrator.testautomation section of the cluster configuration file, the uipathctl binary ignores the connection string and uses the one under the orchestrator section instead. As the following sample shows, the ignored connection string is the value of the sql_connection_str parameter:
"orchestrator": {
  "testautomation": {
    "enabled": true,
    "sql_connection_str": "Server=tcp:new-sql-server-name,1433;Initial Catalog=new-db;Persist Security Info=False;User Id=test;Password='************';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
}"orchestrator": {
  "testautomation": {
    "enabled": true,
Solution
To address the issue, take the following steps:
  1. Perform a Base64 encoding of the SQL connection string that you provided as the value of the sql_connection_str parameter:
    echo -n "<sql_connection_str under orchestrator.testautomation in cluster config file>" | base64 -decho -n "<sql_connection_str under orchestrator.testautomation in cluster config file>" | base64 -d
  2. Run the following command to edit the orchestrator-secrets secret:
    kubectl edit secret orchestrator-secrets -n uipathkubectl edit secret orchestrator-secrets -n uipath
  3. In the secret, update the value of the sqlConnectionStringTA parameter with the Base64-encoded connection string value.
  4. Check if you successfully updated the connection string value:
    kubectl get secret orchestrator-secrets -n uipath -o jsonpath="{.data.sqlConnectionStringTA}" |  base64 --decodekubectl get secret orchestrator-secrets -n uipath -o jsonpath="{.data.sqlConnectionStringTA}" |  base64 --decode
  5. In the ArgoCD app UI, navigate to Orchestrator > Details > Parameter > Values > Inside values > Update.
  6. Under the connectionStrings section, update the value of the TestAutomation parameter with the plain-text value of the connection string, as shown in the following sample:
    connectionStrings:
      TestAutomation: <Plain-text value of sql_connection_str under orchestrator.testautomation in cluster config file>connectionStrings:
  • Description
  • Solution
