- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Troubleshooting
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Studio user guide
Using Coded automation in Low-Code workflow
In this tutorial, you can learn how to incorporate a coded automation called CodedResetAssetValue.cs into a low-code workflow. The CodedResetAssetValue.cs automation performs the following steps:
- Retrieves the current value of a specific asset from Orchestrator.
- Compares the retrieved asset value with the input value provided as an argument.
- If the previous asset value does not match the input value, it updates the asset value in Orchestrator.
- Logs messages that indicate the status of the asset value, whether it was updated or remained unchanged.
To use a coded automation inside a low-code workflow, first create the coded workflow, then invoke it in the low-code workflow using the Invoke Workflow File activity. Perform the following steps to incorporate a coded automation within a low-code workflow:
Create a new coded workflow. For this example, name it
CodedResetAssetValue.- Give the following return arguments to the
Executemethod to indicate if the asset value was changed and to provide the asset value:(bool assetValueWasChanged, string assetValue) - For the
Executemethod, add the following input parameters:assetName (string)andassetValue (string).public (bool assetValueWasChanged, string assetValue) Execute(string assetName, string assetValue)public (bool assetValueWasChanged, string assetValue) Execute(string assetName, string assetValue) - Use the
GetAssetcoded automation API to retrieve the current value of the specified asset using theassetNameparameter. - Store the previous asset value in the
previousAssetValuevariable .var previousAssetValue = system.GetAsset(assetName).ToString();var previousAssetValue = system.GetAsset(assetName).ToString(); - Compare the previous asset value with the input asset value using the
Equalsmethod. - If the values are equal, return
(false, assetValue)to indicate that the asset value was not changed. - If the values are different, use the
SetAssetcoded automation API to update the asset value to the inputassetValue. - Return
(true, previousAssetValue)to indicate that the asset value was changed, along with the previous asset value.
if (previousAssetValue.Equals(assetValue)) { return (assetValueWasChanged: false, assetValue: assetValue); } else { system.SetAsset(assetValue, assetName); return (assetValueWasChanged: true, assetValue: previousAssetValue); }if (previousAssetValue.Equals(assetValue)) { return (assetValueWasChanged: false, assetValue: assetValue); } else { system.SetAsset(assetValue, assetName); return (assetValueWasChanged: true, assetValue: previousAssetValue); } - Give the following return arguments to the
Create a low-code workflow. For this example, name it
WorkflowUsingCodedAutomation. -
Add an Assign activity and assign a value to the
assetValuevariable. -
Add an Invoke Workflow File activity and invoke the
CodedResetAssetValue.cscoded automation. Add the required arguments.Note:For Windows projects: In the Invoke Workflow File activity, select Browse for File and change the file extensions you're browsing for, from Workflow Files (
*.xaml,*.uiwf) to All Files (*.*). This allows you to view all files, including.cs.
Add an If activity, and log messages for the scenarios where an asset value remains unchanged, and for the scenario where an asset value is updated.
